Denon s301 has stopped playing cds but does play dvds
SOURCE: Player does not recognize or play CDs
Thats how some manufacturers sell there replacement parts as they come into the country assembled. it cost let to import but more for us. i once needed a spindle motor for a unit, no replacement except the manufacturer part. Had to buy entire laser assy and thats what they bare selling you too. If you already tryed to manualy clean the lens, look on the side of the laser pick-up. it might be made by sony or a popular manufacturer go by the number printed on the label on the side or bottom of the laser assy unit itself. Good Luck
SOURCE: Dvd doesnt play but cds do
Hi
The problem might be due to hardened greasing. Did You replace the drive or only the laser? The mechanism is named VED-0378, which is also the name of the laser. It is a Panasonic/matsushita thing. Try to google the name and find a dealer near your area, if you can't find it this polish electronic pusher is able to deliver both laser or mechanism: www.impelshop.com
Best regards and good luck! The Denon thing is worth a try.
Niels Peter from Denmark
SOURCE: Denon 3910 won't load some dvds/cds and vibrates while trying.."disc error"!
I have the Denon 2900 (about 4 years of use) and until recently, suffered from the same (growing) problem. CD's were very difficult to start/read. I recently found advice which I tried and was succesful with. It was manually cleaning the laserlens. I took away the outer housing by unscrewing all off the on top (6), side (4) and the back (2) bolts. After that I took out the top plate of the laserunit which took two very little screws taking out. Now you are looking at the cd-tray with the lens. Take a very soft and clean cloth and moisten it a little bit with clean water (be very carefull with the moistening, don't allow any waterdrop to come out of the cloth into the laserlens while cleaning! Carefully clean the lens and dry it with a dry part of the same cloth. Replace the top plate and the outer housing and the player will recognize the discs like it's new again. Good luck! Robert Jan, The Hague the Netherlands
SOURCE: Denon s301 wont play new
Simple thought... are you trying to play a Blu-Ray Movie disk on a Denon that not Blu-Ray Compatable? That would do it.
SOURCE: My Denon DVD 955 frequently fails to play audio
hi,
in dvd player this problem can occur when there is a problem with the spindle motor. it will not rotate at the required RPM for cds. just check the spindle motor. if available replace it and try again.
ok
