TOILET/SHOWER OVERFLOW DRIPPING. OTHERWISE WORKS OK
SOURCE: dripping shower head
If it is dripping from the connection where it goes to the water spout you can unscrew the connection and wrap teflon tape or Pipe Joint Compound on the Threads. Now you can Thread the Shower Head Back on, with No Leak. IF..... It is leaking from the Shower Head Itself There May Be a Problem with the diverter handle/lever. If it has a Pull Type Lever, sometimes you can screw the Lever up or down for the proper water restriction to the Shower Head. However if the Hot and Cold Handle/Lever is OFF, There should not be any Water coming out from anywhere! If water is coming out off the Tub Spout, with the Shower Off, then you will have to replace some washers or Cartridges in the faucet(s) to stop the dripping. You can do this easily....Just Ask) Remember though, that some shower Heads may Drip for a Few Minutes After they are Turned off. There is still water in the Supply neck and needs to escape, either though the tub Spout or Shower Head.......Hope this Solution Helps you with your Drips.....Joe
Posted on Feb 01, 2009
SOURCE: triton opal 10.5kw shower runs
probably needs a replacement stabiliser valve assembly- about £29 each. look in your user guide
Posted on Jul 17, 2009
SOURCE: Moen shower head drips. Single lever shower only.
Probably need to remove and replace the cartridge. Often sediment will tear part of the o-ring or seal on the cartridge and cause this problem...
varies by model, but generally, remove the cap on the knob, unscrew the knob, remove the keyed sleeve, remove the round trim plate & shut off the service stops (verify they are fully closed by pulling out on the valve stem) next remove the retaining clip (needle nose and be gentle) that holds the cartridge in place, then pull the cartridge straight out with vice grips or similar (or get a puller). clean the cartridge, flush out the valve body by slightly opening both service stops, reinstall cartridge and clip, open service stops and see if it still leaks. if it does, take your cartridge to the store (any reasonable HW or plumbing store should have a replacement) and get a new one. then reverse the process to reinstall.
If you send me the model I'll get you more specific instrucitons and pictures...
Posted on Oct 11, 2009
SOURCE: turned on a triton trance electric shower it was
The overflow pipe is a pressure relief device which is a small rubber ball that get's ejected when the water pressure inside the shower is too high. You will need to get a spare part to replace this. These generally operate because the showerhose is in poor condition and has collapsed internally, or the showerhead has become clogged up so check these things first.
Good luck.
Posted on Nov 03, 2009
Nov 19, 2015 | Town Home
Sep 16, 2012 | Home
Jun 22, 2011 | Thermasol Electrical Supplies
Mar 17, 2011 | Kohler Toilet - One Piece with Ingenium...
Jul 18, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
May 14, 2010 | Home
Jan 19, 2010 | Eljer Aqua-Saver 12" Two-Piece...
Oct 15, 2009 | Toto Promenade, 1.6 GPF, Elongated...
Feb 19, 2009 | 1998 Ford Escort
Dec 04, 2008 | Saniflo SaniPlus-Round SaniPlus Macerator...
Aug 09, 2017 | saniflo"" turboflush toilet"
