Question about Laser Phaser 6280v_n 25ppm 256mb - XEROX & VISIONEER - 6280V_N Printer
ADC sensor error code 092-651 phaser 6180mfp - Laser Phaser 6280v_n 25ppm 256mb - XEROX & VISIONEER - 6280V_N Printer
1 Related Answer
ida_ns22
SOURCE: XEROX 6280 ADC SENSOR ERROR CODE 092-651
you have to replace your transfer unit
Posted on Feb 07, 2011
What does this error mean when I'm trying to scan to email on our Phaser 6180MFP? Error 016-506
Failed to login to the SMTP server. Use CentreWare IS to verify that the user name and password settings are correct.
Mar 23, 2015 | Office Equipment & Supplies
I have changed the image drum i now have error 092-310
This code indicates a failure in the ADC Sensor circuit. Fixing it does not seem to be for the faint of heart . If you are feeling brave check out this thread:
http://www.copytechnet.com/forums/xerox/21835-xerox-7132-error-code-092-310-a.html
Sorry I could not offer you a definative solution directly.
Oct 31, 2013 | Xerox 6500/N Phaser Laser Printer
Phaser 6180MFP has error code 133-290 how to correct, and what is it.
Hi, the error code you mention suggests you are able to print a start page but still the error is constantly displayed on the device.
This error is related to a failure on the Fax module, originated by a possible corrupted job on the device memory.
3 Ways to solve this.
  1. Unplug the device from the power cord and leave it for around 10 minutes. Then plug the power cord back on. This will allow the memory to clean.
  2. Clean the memory. Before you do that print a configuration report to ensure you keep all configuration data, such as network information. On the front panel navigate to System > Admin Menu >Maintenance > Initialize NVM. Be aware this procedure might erase your network configuration. therefore is important to print the configuration report previously
  3. The same steps taken in Step2 will be required but done on a Diagnostic menu. For this I would advise you to contact Xerox to get an onsite visit.
Hope this helps. Regards,
Oct 04, 2010 | Xerox 6180MFP/N Printer
Xerox Phaser 6180MFP i have replaced toners
There are a couple of possibilities here.
Is the printer on a 'page pack' contract ?
Are the toners really chipped for the printer you have ?
There are 8 printers (including the multifunction variants as yours is) that take a SIMILAR cartridge.
They vary in capacity and chip. Some remanufacturers don't realise and have been sening out cartidges for these with the wrong chip fitted.
There has also been a bad batch of chips (a while ago now).
The solution is quuite simple, contact your supplier tell them what the problem is (error message etc) and they should be able to check the cartridge in their test printer (a GOOD remanufacturer will have a test printer for each of the cartridges they produce - how could they test their product otherwise !!).
Oct 09, 2009 | Xerox 6180MFP/D Printer
Xerox phaser 6180 mfp error code 133-290
Before attempting to resolve the error 133. -290, print a copy of the configuration report on the copier / fax. Use the navigation on the front panel to access the configuration menu to get the impression. Review printing to make sure it understands the network settings. This is a protection against configuration settings being lost when you troubleshoot.
Clearing Memory reset the memory of the Xerox Phaser 6180MFP, Dell 3110cn or Dell Machine 3115cn to erase the stored contents and eliminate corrupted data. Disconnect the analog line and power cord from the printer. Wait at least 10 minutes. Then reconnect the analog line and the power cord. As the machine starts, press the "All Clear" "Stop" buttons to prevent automatic printing of the status page. Check the error display panel 133 to 290 times the machine is fully initialized.
Corrupt Adjustmen
Jun 20, 2009 | Xerox 6180MFP/N Printer
Laser Phaser 6280v_n 25ppm 256mb - XEROX & VISIONEER - 6280V_N  Printer Logo
241 people viewed this question
Top Laser Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Barbat Nae
Barbat Nae
Scott Kalvinek
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
