SOURCE: i need a manuel for a phillips 42pfl5522d/05 lcd
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, and a list
of Dealers for spare parts, as required. Just Google the manufacturer's name and
follow the links. Make certain you are directed to the manufacturer's
web site as some search engines direct you to other sites and they
charge for the information that is normally free of charge. I
hope this helps.
SOURCE: my son pressed a button
You could try switching the tv off at the mains for a couple of minutes. This should get it out of the setup menu.
Please dont forget to vote if you liked my answer thanks
Have a look on ebay for a remote control.
SOURCE: how to locate and remove
inverter boards are usually all the way to the left or right of the panel. if you open your tv..looking at it there should be a brown board which is you power board. then theres a board that you plug in all of your components to, its green, thats the main board. at the top or bottom is a smaller board thats the controller board. then on the left or right are your inverter boards, some lcds have multiple.
Please take the time to rate :] thanks!
SOURCE: 42pfl5522d/05 tv screen is blue and cant tune or
With the TV on pull out it's AC plug and leave it for a few minutes (10 minimum)
Then switch off the manual switch you left on, on the TV set.
Plug in again and turn on the TV by the manual button (this should be standby mode) then turn fully on as usual by the remote control.
It may need complete or part setting up again per the instructions but you'll hopefully find that all will soon be well.
thanks
I hope this helps.
