Auto switch doesn't work. it stays on
SOURCE: ativa DQ120D shredder
I had the same problem with my Shredded. In the centre of the paper feed slot is a little sensor that detects when you put paper in, it breaks some sort of light beam that is connected to the motor circuit.
Over time paper dust gathers on this sensor, covering it completely and fooling the machine to think that there is ALWAYS a piece of paper being fed into the shredder, the result being that the motor just runs continuously.
Clear the dust from this sensor and you'll fix this particular problem - a toothbrush worked great for me - don't use it to clean your teeth afterwards :-)
FIXYA!!!
SOURCE: Ativa DQ 120dDoesn't run in auto
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc board, contact manufacturer for more info.
SOURCE: Need Ativa X1800 Shredder Parts
Hey check out this link they service all types of shredders hopefully they should be able to service yours.
http://www.factory-express.com/blog/2005/10/paper-shredder-parts.html
SOURCE: Shredder won't turn on
I was using my Ativa DX180D and it was working fine. It just stopped and there was no power. I have tried all the plugs in the house but still not coming on. The basket is on properly and you can hear the click of the switch when you plsce the top on the basket. Any suggestions?
SOURCE: Ativa X1000 paper shredder that doesn't turn on
took the shredder section apart, cleaned out the gears of paper and a broken mount (plastic piece), and hand turned the electric motor to free it up. After assembly, the ready light works and so does the FWD/REV directions for shredding.
