I lost the keys to my back door yale lock, how do I get another one?
Posted by June Allen on
LEONARD MCCARTHY
  • 189 Answers
Somehow your answer ended up in the Office Shredders problem area. I suggest you resubmit your answer to the correct problem area. When you do, clarify if the lock is installed in the door, in that case, either 1) remove the lock and take it to a locksmith to make a new key (It is expensive if they come to you) 2) Buy a new lock and hide a spare somewhere safe outside your house 3) If it is a pad lock, cut the lock and get a new one.
Posted on Dec 10, 2013
How do I open my Yale Home Safe YSS0000NFP. The batteries have gone totally flat.
Yale battery operated safes have a manual override function for which keys are supplied.
Nov 14, 2014 | Locks & Locksmithing
How do i reset a yale series 150/30 padlock
this step by step guide should help you reset the lock, if its not the exact same lock, its the closest thing that Yale currently makes. Be aware you cannot reset locks like these unless they are open already, atleast not to my knowledge
Combination Cable lock Reset the combination of Yale travel lock Secure...
Jun 06, 2014 | Yale Y150/30/125/1 Combination PadLock
How do I remove the cylinder from a Yale Y130/70/116/1 padlock so I can remove a broken off key.
You can't. Make sure the cylinder is in the upright position, and tap the lock on a bench face down (very hard) it may dislodge it enough to grab it with some tweezers.If no luck, throw it away.
Feb 25, 2014 | Yale Y130/70/116/1 Marine Grade Stainless...
I bought a lock bow it has a yale combo lock, don't have combo, only numbers I found are V5908 on it, took back off and all parts fell out, need help trying to put back together and maybe get it working,...
Look sorry to say but you have created a mess. Now what you have to do is to visit the San Francisco Locksmith website and see the manual guide to fix it. The better option is to hire their services or contact with them to know about fixing this issue.
Oct 30, 2013 | Yale Y150/30/125/1 Combination PadLock
How to fix the back passenger door lock on 2008 VW Jetta?
Its neccesary to move the secures for the part vinil and plastic, the yale and , review and repair the door look
Sep 19, 2013 | 2008 Volkswagen Jetta
Eruo cylinber lock on one side of french doors jammed and cant open it and cant get the barrel out can anyone help
does it have a keyhole both sides ?
If so, you will need a Locksmith to pick the lock open first.
Oct 24, 2012 | Yale Locks As3535pb 35Cm/ 35Cm Anti-Snap...
The lock on the front door, the hardware around the thing you put the key into is loose,,,how can i tighten it
Assuming this is a 'yale' type latch key lock.
Unscrew the lock assembly from the inside of the door. Behind it you will gain access to fixing screws for exterior assembly - just tighten them up.
Feb 16, 2011 | Garden
The Yale lock on my Front door in becoming increasingly difficult to open with the right key. I'm worrie dthat one day soon I wont beable to open it at all. What is wrong with the lock? Could I use...
Yes I would useWD-40 to spray in lock. Insert key part way in lock and spray a small amount on key and into lockset if tou can, If you can fit spray nozzle into keyhole ,and spray liberally. You can also use dry graphite to lube lock mechanism. I would check to make sure that your keys aren't bent or worn to the point that I hope this helps you. Thanks they can't engage all tumblers inside lockset. I would also make sure that latch on lock is lining up with strike plate in door frame. One easy way to do this is to use a felt tip marker to cover strike plate on door frame and open and close door several times. Where ink from marker is rubbed off will show you where latch is contacting strike plate. If it is out of aligmment this will make it harder to open or lock with key. If necessary adjust strike plate for better fit. I hope this helps you. Thanks
Nov 17, 2010 | Garden
42 people viewed this question
Marvin
Marvin
