SOURCE: water continues filling and overflows
Our LG WM-2432H front load washer was overfilling. I got the service manual from LG on the web ( http://136.166.4.200/contents/Laundry/WM2432.htm )
and the most useful thing in that manual was a listing of special control codes that can be entered from the front panel, for example to turn on the drain pump.
I thought maybe the sensor switch was broken, but after disassembling the machine I discovered that the 3/16" ID rubber hose between the sensor switch and the bottom of the tub had shaken loose from its supports and through dragging on the back of the tub during spin cycles, had worn down and had a hole in it, allowing air pressure to leak.
After vacuuming up the shredded rubber, I replaced that tubing with a three foot length of 3/16" inside diameter fuel line purchased from a local Lowes store. I used some twist ties to secure it to the back of the washer housing so it would not drag on the drum. The washer now works fine.
You can do this whole repair by removing the back access panel, only four screws. Look for shredded rubber; the hose just slips off of the sensor and the tub connect points at both ends.
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
SOURCE: My LG front loader is washer leaking water.
Could be the bladder from the drum to the door of the door seal. It could also be the drain pump hose.
SOURCE: my lg top loader washer continously drains water and never washes
I was solve resolvbe it in a most simple way.
SOURCE: Lg top load washer e6
E6 is listed by Samsung as :- Water temperature rising/falling too quickly. Check thermistor.
