SOURCE: my toshiba estudio 3500c prints my photos with a
try adjusting the settings in your print properties such as rendering (presentation, photographic, etc.) also can make some adjustments in print tab in user tools as far as gamma adjustments, may have to go to admin mode default password is 123456
SOURCE: how do I fix fault code C448 on the Toshiba E
C448 means you have a fusing unit malfunction. The fusing unit is the part that gets hot just before the paper comes out of the machine. You can try clearing the code using this reset procedure:
(1) Turn the power ON while [0] and [8] are pressed simultaneously.
(2) Key in "400", then press the [START] button.
(3) Change the displayed current status counter value "32" to "0", then press [ENTER] or [INTERRUPT] (to cancel C448).
(4) Turn the power OFF and then back ON.
If the code comes back you are going to need a fusing unit.
SOURCE: toshiba estudio 351c error code
Hi [CE40] Image quality control test pattern abnormality (1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color. (2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" to check if the low-density pattern abnormality occurs for each color. The values under 320 for Y, M and C, and under 220 for K are defined as low-density pattern abnormality. (3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" to check if the high-density pattern abnormality occurs for each color and identify the color which pattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality. (4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image quality closed-loop control / Laser power (08-557)" to "0" (Invalid). (5) Perform "Enforced performing of image quality open-loop control (05-394)". (6) Output the image quality control test pattern (04-270) more than one time and check the patch of the color identified in step (3) to see if the image is abnormal. (7) Replace the image quality sensor. (8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image quality closed-loop control / Laser power (08-557)" to "1" (Valid). (9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it is completed normally. (Error [CE40] does not appear.) (10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576). Good Luck Regards
I hope that this will help you
SOURCE: CE40 ERROR IN TOSHIBA COPIERS
CE40:Image quality control test pattern abnormality: The test pattern.
Switch off at the right hand side of the machine, wait 10 seconds, then turn it on back again. I should clear.
I think it is caused by condensation, it can also be transfer belt failure, or paper rubbing against the transfer belt
SOURCE: Toshiba estudio 2830c error code ce40
I want to locate the position of the image sensor for a toshiba E-Studio2500c.
