Question about Lexar Media Jumpdrive S73 - Usb Flash Drive - 16 Gb
Lexar 16GB S73 appears as Innostor NAND Flash USB Device
Despite being used before, the flash drive had to have it's driver installed last time I plugged it in which resulted in it appearing as Innostor NAND. I can no longer access the files on it and have had no luck with changing the drivers back to Lexar due to the S73 driver not being present on the Lexar site or anywhere else I have looked. Any ideas? Thanks in advance!
Posted by Chester on
bayou sam
    Passionate:
    Visited the website for 10 consecutive days.
  • 126 Answers
USB flash devices don't need drivers. I believe you might have removed one or both of these drives from the PC without using the proper procedure, and the PC (or notebook) is now "confused". Re-attach one or both devices, but this time, either use (Windows) Explorer to "electronicaly" eject the device (right click, then choose eject) or use "Safely Remove Device" shortcut, usually on the bottom right=hand corner of your screen (the taskbar).
Posted on Sep 11, 2017
5 Related Answers
Anonymous
  • 86 Answers
SOURCE: Lexar 2GB can't retreive jpeg's
download and Try this free utility- http://www.bestfreewaredownload.com/freeware/k-usb-t-free-undeletemyfiles-freeware-cnsyjket.html
Posted on May 06, 2008
Anonymous
  • 86 Answers
SOURCE: lexar flash drive
First, download and try to extract all the files from your drive with this tool:
http://www.lexar.com/drivers/files/ImageRescue_2.0-u(b16).zip
Second, at the moment that you are sure that you have all your files backed up, if windows recognizes the drive, try to right click on it and format
gotgeek2
Bob
  • 565 Answers
SOURCE: How can i recover my files from my usb flash drive?
It's possible that you are still suffering from the effects of the virus. You can try to download a (free) program called "Restoration" and run it. Here's the link:
http://www.download.com/Restoration/3000-2094_4-10322950.html
If you manage to recover your files, I would recommend that you re-format the flashdrive to make sure that you are getting rid of the virus, then re-install your flashdrive software if you use it.
Posted on Jan 28, 2009
ericb777
  • 24 Answers
SOURCE: How to recover data from a seemingly dead/non-functional USB flash drive
It sounds like your media is malfunctioning (electronics).
For this type of problem, we offer a data recovery service.
You simply have to send your media to us.
Our technicians will recover your files on CDs and return everything
within 48h. You just need to send us your Lexar with this form:
http://www.lc-tech.com/documents/LC_Technology_Data_Recovery_Service-SD-Eric.pdf
There is a charge for this service, but ONLY if we
are successful. The pricing is on the form. Please note
that the chances of recovery are around 90%.
Eric Beaudoin
[email protected]
1-866-603-2195 ext 103
LC Technology International
Posted on Jun 25, 2009
sunnylab85
Sunday Ojelabi
  • 302 Answers
SOURCE: flash drives are not working but other usb devices are working
the flash has spoiled it can work again, because auto run that is in it has been disable.
Posted on Aug 27, 2009
How do i get my computer to recognize my usb flash drive
If your device drivers are up to date, the USB ports are totally recognized. If the USB device plugged into the port is not initialized, it may not be recognized by the computer operating system. If a USB flash drive was working and no longer works; it could have been damaged when removed from the computer when last used. Flash drives are sensitive to Static Charge. Like when you rub the feet on a carpet and a spark of electricity jumps from a finger to another person. You must use the Eject method when removing Flash Drives.
Feb 10, 2018 | Computers & Internet
Cannot format s73 jumpdrive
If using a PC, considering you have the USB driver installed (perform windows update first and install any suggested/required updates), plug in the flash drive, open the windows explorer, locate the flash drive, right mouse click on the name of the drive, a window should appear and select format with a left button click to execute.
Dec 22, 2013 | Lexar JumpDrive S73 - USB flash drive - 16...
can you please confirm whether you can see the drive under 'My computer' or not? If you do and you said the files aren't that important, you can choose to reformat it through right click -> properties
Dec 09, 2013 | Lexar Media Jumpdrive S73 - Usb Flash...
I have last my installation cd
You don't need to install any software in order to use your camera.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Jan 27, 2013 | Vivitar ViviCam 6320 Digital Camera
How to use flash drive
you just need to plug in the usb hard drive to a usb port when the computer is turned on & you get the desktop. a message will appear "new hardware found" & then " installing driver for usb hard drive". when you get the finish installing driver message, you can use that drive.
Sep 22, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to use pendrive in widows 7
Windows7 If drivers are required they will automatically be installed when you are connected to the internet.
So plug-in the pen drive and it should work immediately as most pen-drives do not require drivers.
Just plug-In and look in my computer a new drive will appear
Jun 24, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Despite installing software on computer.when i connect the camera with the usb cable it comes up as unknown device. Have tried reinstalling driver but no joy. Have installed camera previously on another...
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
May 14, 2010 | Samsung Digimax V800 Digital Camera
Lexar Media Jumpdrive S73 - Usb Flash Drive - 16 Gb Logo
210 people viewed this question
Top Lexar Computers & Internet Experts
Colin Stickland
Colin Stickland
Harrie
john smith
Are you a Lexar Computer and Internet Expert? Answer questions, earn points and help others
