Will not turn on but clicks about 5 times and standby red light blinks twice green light blinks inside unit have replaced power supply card without success
SOURCE: I cannot get the tv to turn on. The red standby
You either have a bad T-Con bd or a bad Main bd. Have a trained samsung troubleshoot the set.
SOURCE: my tv turns on but no picture or sound
power pack capacitors have failed they will need to be replaced with new ones and that should repair the tv, soldering skill is required to do this or replacement of the entire power pack.
hope this helps
SOURCE: Samsung LCD 40" While LInes, Clicking Noise, Red light blinks
Your LCD has gone bad or their is a high voltage problem that powers the LCD. Usually a inverter board.
SOURCE: tv tries to come on but just clicks and clicks.
There are 3 capacitors in power supply board, all 1000uF10v.
2 for 5vdc and 1 for 12vdc. replace with best quality 1000uF 25V cap.
do it yourself repair will save you $300
SOURCE: Samsung LN46A550 LCD power on/off
Apparently this is a known problem with flat panel TVs made a few years ago due to bad capacitors in the power supply. This same problem appeared in computer mother boards at about the same time so that the capacitors went open or shorted causing problems.There is videos on You Tube that addresses this problem see: http://www.youtube.com/watch?v=ZccykxrtX9g as a starting point and look around for other repairs
514 398 065
Four digit code is:
0125
1* Turn your TV and SkyHD box on and press tv on your remote control.
2* Hold down select and the red button together until the red light on your remote
control blinks twice (this is after about two seconds).
3* Press tv again.
4* Key in your TV's brand code. The light on your remote control blinks twice.
5* Press standby on your remote control.
If your TV switches off, press select.
The light on your remote control should blink twice.
If your TV does not switch off, press tv, then press standby.
Repeat the sequence of pressing tv then standby until the TV switches off,
then press select.
If the light blinks three times, your remote control has checked all the possible
settings for the code you used. Check you have the right code and start again
at step 1.
*6 Turn your TV back on and press the tv guide button on your remote control.
The TV Guide screen appears, meaning the remote control settings have
been reset.
