Question about Stihl Concrete Cutoff Chop Saw Clutch Ts400 Ts 400
SOURCE: trying to start a stihl ts 400 disc cutter i
Try cleaning the plug and spray some starting fluid in the carb.Hope this helps and Thank You for asking!!!
Posted on Jul 19, 2010
SOURCE: hi there; my stihl ts 420 does not start easily
replace the decompression valve. also check for carbon buildup on top of piston. usually when a saw stops on its own after 5 min or so.... the piston and jug are scored and need to be replaced.
Posted on Aug 03, 2010
seems that ur clutch is sticking.take recoil caseing of and check by turning blade by hand,if you feel the engine turning over,then your clutch drum is sticking,be sure to remove ur spark plug cap! it will be the bearing at the rear of the clutch drum,maybe a little oil and a few turns will help it free itself.hope this helps.
Posted on Jan 30, 2012
Apr 04, 2016 | Stihl Saws
Mar 25, 2013 | Stihl Ts 410 420 Cut Off Saw...
Aug 14, 2012 | Stihl Ts 400 Ts400 Carburetor Carb Rebuild...
Mar 17, 2012 | Stihl Concrete Cutoff Chop Saw Clutch...
Dec 06, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
May 30, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
Oct 02, 2010 | Stihl Concrete Cutoff Saw Rewind Recoil...
Jul 19, 2010 | Stihl Concrete Cutoff Chop Saw Clutch...
256 people viewed this question
