Question about Intertherm P3RA-048K Air Conditioner
Furncace won't stay on - Intertherm P3RA-048K Air Conditioner
Posted by Nina on
  • Brian Mills Dec 12, 2013
    Hi Nina , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Car won't stay running
If the problem only happens when the engine is cold, a bad electric sensor is likely to blame. If the car stalls even when the engine is warm, the cause is likely a faulty electric fuel pump.
Why is it that my car starts but won't stay running? ' Reference.com
https://www.reference.com/vehicles/car-starts-won-t-stay-running-6449388a9326285d Car won stay running Google Search
Dec 15, 2016 | Cars & Trucks
My asb light comes on when starting and stays on. Lights won't come on , power locks won't work, power windows won't work, radio won't work. All fuses are good and car runs fine.
Those are all really common symptoms of the alternator going bad on those cars. I would have it checked to make sure it's charging properly.
Dec 15, 2012 | 1996 Oldsmobile Cutlass Ciera
My ps3 system won't stay online. I have to always
Yes you may need to pick up a new wifi range extender because it sounds like it's almost burned out.
May 15, 2012 | Sony Video Game Consoles & Games
My carrier 58sta furncace is blowing cold air constantly
Code 33 is "limit is open or flame switch is open"
FIRST make sure the filter is clean. Turn off unit then turn back on.
if it works but then later gives you a 33 code then you might have a dirty a/c coil (if you have a/c) that will cause the limit to open. 1st try that
Mar 21, 2010 | Carrier Heating & Cooling
Furnace leaks water on floor when air conditioner is running.
Okay, let do this;
get a wet/dry vaccum set the suction into the drainage and let it **** it.
it should solve your problem.
[email protected]
Jun 09, 2009 | Intertherm P3RA-048K Air Conditioner
Doing furncace swap i have no air conditioning conectect red to r yellow y and green it blows air not ignite
You should have a white wire connected to W of the t-stat. You mentioned only 3 wires. On the furnace connect the red to R the Yellow to Y and green to G I think you got that right but one wire is missing.
Nov 26, 2008 | Whirlpool Heating & Cooling
Intertherm P3RA-048K Air Conditioner Logo
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
