I inserted 4 (C) batteries and the engine makes noise, but it won't move forward. I have a feeling there is another place for a battery, but have looked all over. Tried several new packages and nothing changed. Any advice?
The market is replete with different Easter eggs for Easter decorations. It all depends on your budget. How much are you willing to pay? If you do not want to spend money on buying Easter eggs, you can always make your own Easter eggs.mesaje de paste, urari si felicitari prin SMS de sfintele pasti You just need to show some artistic skills and you can have your own Easter eggs painted. Easter decorations could be made unique with your creative skills.
Are/was the battery terminals corroded ? May want to pull the batteries out and clean the contacts. The side for the other functions may be corroded.
SOURCE: New Bright Model #183 - how do I make the train
This train set is very particular and getting it to work each Christmas is a family tradition in frustration. First you must make sure that all the pieces of track are connected properly and that the track is perfectly symmetrical and flat. We double-check the battery positions every year and find one in wrong. There are + and - signs, but they're hard to see; use a flashlight. There is a black toggle switch below and behind the red stack that toggles forward (to make the train go forward) and backwards (reverse); straight out perpendicular to the train is the "stop" position. Also, you have to start at a stop/switch station. One other note: behind the red stack, there is a smaller black stack. If you turn this, you can make smoke come out of the stack. I think I remember someone suggesting a drop of cooking oil. Hope this helps!!! Hope you get it set up for Christmas!!!
SOURCE: locomotive won't come on
SOURCE: Scientific Toys train won't run
WELL WHERE EVER YOU BOUT IT FROM YOU SHOULD TRY TAKING IT BACK THERE AND GETTING THEM TO LOOK AT IT,TAKE IT TO THE SHOP,OR BUY A NEW ONE. :)
SOURCE: remote control train won't work
The wires will have pulled off the circuit board inside.
Remove screws (force a hex driver in there) and solder wire back on.
Train surgey (geddit) is very fiddly. Have a drink first! ;-)
SOURCE: GEOTRAX REMOTES ARE NOTE COMMUNICATING
I had the same problem with two of our three engines. I read somewhere that you can get them running by hitting the side of the engine against a hard surface. I can't believe it... IT WORKED! I guess the motor gets stuck and hitting it will get it going. All three engines are working now.
