Question about OKI C Office Equipment & Supplies
Need to know where the reset fuses are located for the fuser and the transfer belt on Oki c6050n
I would like to be able to reset the fuser and transfer belt on a Oki c6050n. If someone can tell me where the fuses are located it would save me some time disassembling and exploring. I have reset the drums to 100% using an analog ammeter and would like to be able to do the same for fuser and transfer belt.
Posted by Thomas Pell on
3 Related Answers
Soulvisitor
Soulvisitor
  • 1113 Answers
SOURCE: oki 9800 230 fatal error
No reset need to fix fault then clears...check toner carts are secure on drums, all their contacts are clean,
Replace Toner Cartridges with Gen OKI new ones... are you using non oki product? Cause Toner carts, thats where I would start looking cause the error is the machine not receiving correct information from a little chip built into the toner cartridges to allow operation to begin.
Posted on Dec 21, 2007
Anonymous
SOURCE: oki 5500 n
You cant do it via admin code or software.
Inside every part is a little green picofuse.
When the printer starts, it looks for continuity. If present, it burns the fuse and resets the corresponding counter.
If you want to be creative, you can replace the little fuse. Easiest done in belt and fuser. Almost impossible in drums.
Or one might construct a little device with a fake fuse to insert between the part and the corresponding connector.
Posted on Dec 17, 2008
alpug
Danilo Baraquiel
  • 1961 Answers
SOURCE: I have an Oki c9650
not 8 0\'s...... use only 6
password is 000000
Posted on Oct 18, 2010
Oki c5800 belt life reset
It may require a complete service kit, you should check with Okidata to see if there is a kit available or what steps you should take to reset the life counter.
Jan 29, 2013 | Oki Electric Industry Okidata C5500, C5800...
I need to know the size of the IT Belt reset fuse in an Oki c5500
Have you contacted OKI Data? Live customer support is available 24/7 (within the US and Canada) at 1-800-OKI-DATA.
Jan 14, 2013 | OKI C5500n Printer
All three lights blink rapidly. The computer says it cannot communicate with the printer. When I plug the USB into the computer the computer doesn't acknowledge that anything was plugged in. If I...
It sounds like your main board (the brains) in the printer is fried (I got the same problem with mine). That part (when purchased new) costs so much, your better off just getting a new printer, and it's not your typical user serviceable part (hard to remove, many wire/plugs going to/from it).
The problem with replacing it with a used part, is that the used circuit board will still have the consumable counters in it set to old values from the printer is was pulled from, and NEW or RE-Chipped consumables will be needed to reset those back to zero again (not just the toners, but also the photo drums, fuser, and transfer belt). So, if the used board was connected to "old" consumables (nearly depleted), you won't be getting too many prints before it's asking for either new toners, photo drums, fuser, or transfer belt. The fuser and transfer belt cost upwards of $175 or more each....
How it works is like this, according to Okidata's Tech support guys. When you put a new "consumable" (toner, photo drum, fuser, transfer belt) into the printer, that main board resets the counters AND THEN it immediately blows a fuse (not a regular fuse, but a microchip fuse) in that comsumable so it can never reset the counter for that consumable again. When that consumable's counter reaches it's predetermined number of prints, the printer refuses to print until it is replaced (or it is "re-chipped" with a new fuse).
They make toner refill cartridge chips, and I think even a photo drum kit (seen it on Ebay). But I haven't found anything that would rest the fuser or tranfer belt. Let me know if you find something to reset the fuser or transfer belt.
Jun 10, 2011 | OKI C3400n Laser Printer
My Oki C5800 says "Replace Belt, 355: Belt Life" but I was told I could reset it without changing it if it was still good. How?
requires a fuse that sits underneath the transfer belt. However the belt itself would be full of waste toner that would need to be emptied
Jun 30, 2010 | OKI C5800Ldn Led Printer
HOW DO I RESET THE FUSER ON AN OKI C710
Check online for a fuser kit for your machine, OKI machines use a fuse installed on the new fusers that reset the count and then burn out. The fuse is Littlefuse #251-062
Feb 01, 2010 | Oki Electric Industry OKI C710dn - - color...
Oki 5500 n
Dec 09, 2008 | OKI C5100n Laser Printer
Fuser reset / transfer reset
RESET OKIDATA TONER DRUM by RTINSC (11/17/05 10:34 AM) reply + / -
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 11, 2008 | OKI C5510 MFP All-In-One Led Printer
Oki 9800 230 fatal error
Dec 07, 2007 | OKI 9800hdn Laser Printer
52 people viewed this question
Top OKI Office Equipment & Supplies Experts
Alvin Barnabas
Alvin Barnabas
Timothy Van Der...
Mike
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
