Vision quest renoir
We have a vision quest 32 inch tv, product no is lvq-32lha. the green light at the lower left corner keeps flashing and does not turn on. i have tried the soft reset but still the same.
Posted by 3011shimaa on
wisiny.com
    New Friend:
    Problem Solver:
  • 18 Answers
First check the power supply of your TV,multimeter the export voltage of power supply.if it is defective you can replace it.
if not you need check main boards,and inverter boards
From Wisiny.com can find those parts,power supply,inverter boards and t-con
Posted on Dec 09, 2013
5 Related Answers
Anonymous
SOURCE: Flashing red light, screen doesnt turn on
http://recycledpapyr.us/2009/03/26/blown-power-supply-on-philips-plasma/
I found this solution in an other forum , don;t now if you are experiencing the exact same problem though
Posted on Oct 12, 2009
Anonymous
SOURCE: vision quest tv problems
my screen is upside down i dont know how to fix it help me!
Posted on Jan 15, 2010
Anonymous
SOURCE: tv won't turn on. blinking red light in lower left corner
unplug the television...wait 10 seconds and then plug back in....if you listen carefully after 5-10 seconds you will hear a click sound (the same sound that you hear when you turn on or off) ...once you have heard it, turn the TV on again using the remote. Do not turn on until you hear the click. If this does not work, try again but turn the TV on again before you hear the click. I dont know why it happens but it is as if the TV gets confused as to whether its supposed to be on or off. Most of the time, the solution is to turn it on after the click so I would always try that first.
Posted on Feb 22, 2010
cirocpatel
CIROC TECH SUPPORT
  • 524 Answers
SOURCE: got new tv Westinghouse LTV-32W1 32 Inch
in this case i have to know if your tuner is working fine or not. First of all i like you to connect any external player Exp. DVD or blue-ray player if that works with audio then it is inverter board. if audio doesn't work then its main board. Also you will find out that if dvd is working fine on your tv than your tv setting is wrong or the tunes is dead. either way if tuner is gone then you have to change the main board. Either way let me know what went wrong i can provide you more information about what part need and where can you get it from.
Please let me know if you have any further questions or concerns. Also rate me if you like this post.
Thanks.
Posted on May 11, 2010
Anonymous
SOURCE: Reset Password?
I had same problem, called visionquest tech support for how to reset the tv:
Using the remote, press source then 2580.
A menu should appear, go to other settings then choose restore default. Select yes.
It worked for me - hope it does for you too!
Posted on Sep 09, 2010
I switch on my tv this morning but it dod not come on, instade green light came on with timer signal and keep flashing
Reset the TV to its factory setting, by entering in to its service menu option. Visit the site named 'Electro-help' for more details. Check this link and select the site. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy.
Aug 06, 2012 | Toshiba 36ZP48 36 inch TV
Can anyone offer any suggestions on how to delete/remove titles displaying in the upper left hand corner of my TV screen and right hand corner? For example, if I am watching a program on CITY, the title...
I believe the "Caption Vision" is selected. By pressing the "Display" button on the remote it should toggle through the choices until "Display Off" appears. That should be all.
Mar 05, 2011 | Sony KV-32S42 32" TV
Vision quest tv says tv program blocked
How to unblock a renoir vision quest tv when it says program blocked?
Feb 04, 2011 | Element Electronics FLX-1910 19 in. LCD...
Vision quest tv problems
Mar 27, 2009 | Televison & Video
Panasonic 32 inch LCD TV will not turn on-red light flashing
its not hard to replace the bulb and you can go to any tv shop and have them order it.youll need to give them the make and model number off the back of the tv so they know what to order
Nov 03, 2008 | Televison & Video
sounds like a hardware failure, let me know which model # it is and i will run through service manual.
Oct 23, 2008 | Panasonic TC-32LX60 32 in. LCD Television
Mits diamond vision 65
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Dec 26, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Televison & Video Logo
271 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
