Question about Mitsubishi WS-65807 65" Rear Projection Television
MITSUBISHI WS 65807 RED CRT OUT
Red CRT heater is on replaced ic chip set and resoldered the red crt board the red still only works when it wants to is more not working than working now could it be a driver transistor for the red crt? Is there a way to check this  does anyone know where it is located and where to buy one or could it be something else
Posted by NITRO FISH on
  • 2 more comments
  • NITRO FISH Oct 23, 2007
    problem solved it was the red  crt board
  • NITRO FISH Oct 26, 2007
    swaped the red and green fly back wires still nothing on the red swapped the red crt board to the green light and the green did not work did not work so I thought it was the red crt board orderd one and replaced and still nothing the red still tries to come on every now and than am I missing something is the driver transistor and lamp driver on this board or did they send me a bad board..............
    swapped the green board to the red bulb and the red  works fine. did mits sell me a bad board ??? is there a way to check this board they sell these boards in a set of three r/g/b/ and are used mine a cut and solderd wire I had to cut that same wire to only replace the red board yellow wire with green stripe is attached to the green board they sell these as used with no returns for 83.00 105.00 with shipping but they said these were checked to be good ..........
    swapped all three crt boards from mits from my old ones red did not work  than came on for about a minute went out came on 5 minutes later for a minute now remains out... what is the next thing to check or replace ????
robert landry
    Novelist:
    Scholar:
  • 96 Answers
It' sound like you have a bad crt, to make shure, just disconect the red crt baord and green crt board next to it and move then so you can try the red crt board on the green crt. If it does the same problem in witch I realy thought it's your video or hight voltage sounce on that board. If you get no problem well it's your crt.
I can almost garranty it's your crt.
Bob
Posted on Jan 19, 2008
GREEN CRT OUT OF FOCUS
The individual lens have a lug nut that when loosened allows the lens to be turned-----cover red and blue lens and call up the convergence grid---from the rear adjust that lens until the green lines are in good focus(can also do the red in and the blue if needed)
You will get no more advantage as the manual focus controls on the splitter block have very limited range.
when done carefully tighten the wing nuts on the lens back tight.
Dec 05, 2012 | Mitsubishi WS-65807 65" Rear Projection...
I have a Mitsubishi WS-65807 Projection Tv and while I was watching a program the picture went to a black screen. The audio works fine and when I go to the Menu it shows up fine. Any input as to the...
Thats usually a vertical issue since the menu still works. I would check the solder on the vertical IC and also the Vertical yoke plug pins. Often solder can develop a small crack around the pins and resoldering will usually fix the issue in most cases. The other item could be a leaky CRT has dripped some coolant on some of the components in the vertical circuit so I always check the board for any sign of a clear sticky residule on the boards which indicate dripping CRT coolant.
Jun 07, 2011 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi big screen Model ws-55809 shuts off after powered.
two possible problems:convergence IC(2pc),or hi voltage output:transistor,flyback,capacitors.
Oct 05, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Red and blue overlap shadowing
Sounds like a convergence ic problem, normaly i tell people to replace the ic's but in your case try to re-solder the pins on the ic first, you may just have some pins broken loose from the board. Locate the stk392 ic's there will be two of them located on a heat sink, unplug the tv and get to the bottom side of the board and re-solder the pins. if this does not work, then replace the ic's
Sep 02, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-55809 Color
Does the neck of the tube glow? If not you may have a bad solder connection on the Red CRT PC board or a bad transistor on the red PC board
May 20, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws-65807 no sound or picture
Check for coolant spill in corner of signal PC board = from leaky
CRT seal = bad CRT...........................T.
Apr 24, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Red convergence wont move
if the red line is blurry and you have adjusted the screen focus control and does not work then you prob have a bad red CRT or bad red CRT fluid.........
convergence STK have nothing to do with the red being blurry
Dec 09, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS 55819 with a convergence
CEM-NO, BOTH ICS' WORK ALL 3 CRT YOKES.YOU EITHER NEED TO REALIGN THE RED IN FACTORY CONVERGENCE MODE OR YOU HAVE A RESISTOR THAT HAS FAILED.THE LATTER YOU MAY ACTUALLY BE ABLE TO SEE IF YOU LOOK CLOSELY.OH, ALWAYS DOUBLE CK. YOUR SOLDER CONNCETIONS.GOOD LUCK. JOE TV
Nov 22, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi ws 65807 RED CRT
What I usually find on sets like that is that there is a loose solder joint on the CRT board itslef. You must get to the bottom of the picture tubes, pull off the CRT board from the red CRT and examine all solder joints on that board. Chances are one or more will be cracked, and resoldering all joints on the board should clear up your problem.
Aug 04, 2007 | Mitsubishi WS-65807 65" Rear Projection...
MITSUBISHI WS-65908 red crt going off and on
You don't have enough soder on the STK392-570 unit ! I had to re-soder mine and is OK now
Aug 02, 2007 | Mitsubishi WS-65908 TV
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
654 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
