Http://www.asrock.com/mb/VIA/P4VM8/
SPECS OF THE MOTHERBOARD..
When purchasing RAM make sure ram modules are of the same brand any type
IE corsair ddr3 low density or hynix high density ddr2 you should always try to keep the same brand and type of ram
reason being the compatibility issue
and always place the largest ram module closest the CPU central processing unit
also check the ram sockets for dust and make sure the ram modules are securely seated you can do this by pressing the levers at either end of the ram sockets.
If you're not sure if a module is right for your system, use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules.
First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system.
You should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible.
Hope this helps.
This mainboard uses DDR400 memory
A High Density module is by far much slower than Low Density module at the same speed rating say PC3200/DDR400. High density modules are FAR CHEAPER, less than half the price when compare with low density modules and hence high density modules will NOT work on 90% of today's PC chipsets. LOW DENSITY modules have 100% compatibility with ALL systems and ALL chipsets. HIGH DENSITY modules only have 10% compatibility and are VERY SLOW.
So AVOID those 'High-Density - 128Mx4 config 1GB modules which is usually UNBRANDED and is NO NAME!
With this in mind it is far better to use low density Ram. Most RAM cards today are double sided, it all depends on the capacity of the RAM card.
Please rate this solloution as it it much appreciated.
Thanks.
