SOURCE: ford super duty vibration/shake
The carrier bearing should not move at all. It is mounted in rubber to give a little. But, it should not move freely. If this is the case then something has gone bad. The carrier bearing would cause this vibration as it spins if it is loose.
SOURCE: Front end vibration when accelerating above 45
Have the CV joints checked for excessive play, that is the most common cause of this type of vibration on acceleration.
SOURCE: 1994 f-350 7.3 turbo diesel.tach reading 0 rpm's at idle speed.
yea the 93 to 95 trucks never had a tach that works very long
and first the Tach does not make the od light blink or ck engine lgt
the crank trigger does this little thing is located right in middle front of engine between the vac pump and pwr steering pmp looks like a brass bolt with wires comming out of the back of it costs about 30 bucks (don't forget the locktite blue)
now that should fix the od lights and the ck engine but it may not fix the tach thats done in the tach driver module on back of tach in dash
you can replace this but my vote it's too expensive I did mine just fine with a after market one(50 bucks), bolted it right in front of old one, it hooks up super easy gets it's signal off the alternator stator
im sort of suprized it starts ok with a bad crank trig (eec needs to see +50 rpm to start fuel flow to injectors )
any good shop with a eec scanner can see this in just seconds
SOURCE: 9-01 Ford E350 Box Truck No Rear Tail lights
turn off and on head lights liston for click under hood by your battery, that clicks your tail light relay. It has 4 wires in it. with head lights on 3 wires should be hot. if only 2 wires are hot replace relay.
