Question about Kenmore 53092 / 53094 Side by Side Refrigerator
Ge model tfx30ppda not cold enough - Kenmore 53092 / 53094 Side by Side Refrigerator
Ge refrigerator is not cold enough and ice is not working
What is the model number?
The ice maker will only run if the freezer is at the correct temperature.
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 27, 2012 | Refrigerators
GE fridge/freezer on but no cold air
The main board on the back of the unit has gone bad or in lockout. Try unplugging unit for about 30 seconds. Then plug it back in. If it doesn't start the board is bad. wr55x10942 at about 169.00. Hope this helps. Very common GE problem
Mar 07, 2010 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
GE Profile Artica icemaker does not make ice. model # PSC235GNA. We still get cold water .
use a thermometer make sure freezer is normal operating temp if freezer is cold enough and water is filling ice maker you may have bad ice maker very simple system make sure your getting water 1st thing to check is for water if you have water and freezer is cold youll have ice
Aug 18, 2009 | GE Refrigerators
Where is filter on my ge model tbx25z?
Never seen one with a filter, sounds like you have may have a problem with the cold control. Also could possibly be where the settings on the control knobs are. Put both on 4
Jul 14, 2009 | Dometic RM2852 Refrigerator
Gshs5kgx refrigerator not cold enough, controls
Did you solve this problem? We're having the same problem on our GE same model, but no turbo cool option.
Jul 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is not cold enough
you may have adefrost problem or you need to call in a techincan
Mar 31, 2009 | GE Refrigerators
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 53092 / 53094 Side by Side Refrigerator Logo
37 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
John Tripp
John Tripp
gbob59
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
