I found a site that carrys them, not sure if they are out because just as I was about to order one I decided to try and fix mine since the crack was right up next to the handle.
http://www.svcvacuum.com/bissell/steamer_hose.htm
All I did was unscrew the two screws where the button is for releasing the water on the hand piece. I thin squeezed the clamp together to remove the water hose. Once that was removed I cut the hose and then PRYED out the part of the hose in the hand piece. I then cut the hose down where the crack was. Feed the "water hose" back through the hole in the handle (I heated it with a lighter just a tiny bit to make it soft and worked it through the hole which I just enlarged a slight bit) and with pliers work it back on. Don't forget the clamp. Next just work the outter hose back into the handle but make sure to use a glue or silicone sealer or both.
Even if you get a new hose Im not sure it will come with the handle. To connect the hose to the Machine part just push in that little plastic "dot" and pull out the hose at the same time. Then remove the old hose by the directions above. There is no need to remover the inner clear hose from the machine part, only the handle
