Question about Plantronics Explorer 320 Wireless Headset
Nakamichi bt hp01 pairing with tablet - Plantronics Explorer 320 Wireless Headset
To connect my fintie keyboard to my LG tablet
If that's a BT (bluetooth) kb, you need to go to the tablet Settings, Bluetooth, turn on BT, you might have to tap the More link/button, locate the kb, and add it to get it to pair.
Apr 29, 2018 | LG Tablets & eReaders
Tip
How to connect bluetooth keyboard to Android 2.2 Phone,Tablet.
Well you have a Phone, or a Tablet, and it's a touch screen, now touchscreens are all good, but sometimes one wants, needs? real keys, and a Bluetooth Keyboard should be the answer, but if like many of the people that try to connect a BT KB, to Android phones & tablets, well many, will not actually connect correctly and work. They say ....connected, or ....paired, but they actually aren't connected and one cannot type.. Well if this is your problem, then I may have found the answer, what you need to do is this go into the Settings and go to Wireless, and then Bluetooth, now activate the BTsearch for the, "Device" ie: Keyboard, and at this moment also activate the Bluetooth Keyboard itself's on/off switch, and then hold the pairing key until the LED goes blue and flashes, now, the phone will/should alert you to the fact that you have a "Pairing Request" In the Notification Bar, now, answer this request, quickly, open the Notification Bar, select, and then type in the "Pairing Key", usually Four Zeros 0000, now quickly, go to the keyboard itself, and type in Four Zeros 0000, followed quickly by the "Enter Key"... this is the trick, doing it "Blind" as it were, Now the Phone, Tablet should then indicate it has "Paired" and "Connected" and can be used Also you should see a symbol in the Notification Bar, and the BT Icon will also change to the "Connected" version. Now you will/should be able to use it, just like your touch keypad, in fact in some devices, you can use either at the same time...
I also installed a few apps drivers too, some these may also have assisted me i don't really know, but here they are,
http://www.teksoftco.com/storage/download.php?product=blueinputandroid_apk_18203
http://forum.xda-developers.com/attachment.php?attachmentid=470103&d=1292962995
http://forum.xda-developers.com/showthread.php?t=869747&page=6
The files on the xda site, have 3 files in a zip, you need to unzip these and drop them into the system/xbin, and CHMOD them all 4755 (I usually just 777 all) Use Root Explorer, or ADB, or a Terminal, to do this, after this reboot.
Remember if you don't get a connection or it drops out etc, you will most likely have to reboot, to reconnect, it's a quirk of the BT software i think, it's a pain, but maybe 2.3 will have it all worked out?
on Jun 21, 2011 | Lands Phones
Need product manuel for 8 pure gear blue tooth keyboard
Most keyboards work the same way. Make sure your tablet or phone has BT turned on, and then enable scan more. On the device, hit the bluetooth pairing button. Often a keyboard will send a code to the device that recommends a key sequence needed to complete pairing. Here is a video from the same manufacturer that probably works the same way. PureGear Folio 10 inch
Mar 29, 2018 | Blue Computers & Internet
My tab 4 10.1 won't connect to my new bt keyboard.I have turned off other bt devices and even factory reset my tablet. It pairs but doesn't connect. It connects to my galaxy s3, no problem.
check with the keyboard manufacturer. There may be somehting different about the bluetooth with the 4 that would stop it working there.
Jun 02, 2016 | Tablets & eReaders
My nakamichi paws Bluetooth speaker turns on and then turns off . I have charged it with isn male to male cable but still keeps turning off
I have a BT pen that I have to delete from Devices sometimes so that it reconnect.
Check your Devices-Bluetooth, delete and let it pair up again, just like when it was install the first time.
It also may be a power management issue where the computer turns off connections to save power. You can turn that feature off.
See if that works.
Mar 27, 2016 | Audio Players & Recorders
How to pair Bluetooth speaker to one touch pop7 tablet?
If a Android OS you find the gear/setup, bluetooth and then tell it to scan. You need to make sure you turn the BT speaker on. The brand of speaker should popup on the tablet. Select it to pair.
Oct 18, 2015 | Tablets & eReaders
Where could I find a manual telling care and indicator light meanings for the Nakamichi BT 04 portable Bluetooth Bar Speaker.
Yes, you can replace the battery yourself. The case is most likely heat sealed so you will have to be careful taking it apart so you can glue it back together.
Jan 17, 2015 | Nakamichi Audio Players & Recorders
It pairs for a few seconds then quits
Has the speaker been paired with another device?
Is the device (phone, tablet, etc) paired with another bluetooth device that is within range?
If the answer is YES to either of the above questions this could be what is causing the problem. Please note that most devices (phones, tablets, etc.) can only connect to ONE bluetooth device at a time. Also note that the BT-100 speaker can only connect to ONE device at a time.
If you continue to have trouble feel free to contact the manufacturer at [email protected] or going to http://www.contelusa.net
Jan 18, 2014 | Digix BT-100 Portable Bluetooth Wireless...
Jabra A7010 BT hub will not pair with Sprint BT headset
Have you tired to pair your hub with any other non-Jabra headset? I am trying with Plantronics Voyager 520 without success ;(
Jun 03, 2008 | Radio Communications
Plantronics Explorer 320 Wireless Headset Logo
Top Plantronics Radio Communications Experts
Harrie
MrFixitSTTL
 Mikey
Mikey
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
