Question about Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television
Pt-45lc12 I own a Panasonic PT-45LC12 45IN REAR PROJECTION LCD TV. I noticed today a purplish color flicker on the left side of the screen. I am getting the same flicker on all inputs (componet 1, RGB, etc..) Is this the lamp going bad? or something else?
  • 2 more comments
  • digjoe123 Nov 03, 2007
    It is always flickering and the color is purple.
  • digjoe123 Nov 04, 2007
    how much does it cost for a tube. Is it easy to replace, Where do i go to buy it
  • digjoe123 Nov 06, 2007
    I know this may sound dumb, but are you saying I need to replace the Lamp TL-1500 or are talking about a speicfic green tube light???
  • digjoe123 Nov 07, 2007
    Thank you for your detailed response. I checked again to make sure, but I am getting the purple flicker on all outputs, including the DVD player (while playing DVD as well). So I am to assume the solution is replacing the lamp, correct?
  • 328 Answers
It looks like a problem with a tube (projector light) I suspect the green one. Pay attention to flickering on the lights and post me the results.
Posted on Nov 01, 2007
  • 3 more comments
  • Lyle Siemens
    Lyle Siemens Nov 03, 2007
    Thats good now you know which one to replace. Good luck.
  • Lyle Siemens
    Lyle Siemens Nov 04, 2007
    Here is some info on replacement cost. You should contact Panasonic for the part.
    http://www.dlptvreview.com/dlptvreviews/...
  • Lyle Siemens
    Other places to buy
    http://www.projectorlampcenter.com/Searc...
    http://electronics.listings.ebay.ca/TV-A...
  • Lyle Siemens
    Lyle Siemens Nov 06, 2007
    I think that if your lamp is flickering all the time, replace the lamp. LCD rear projection tvs are very complex. You have to make sure that it is not an upconverting problem with a DVD player too. If no lamps flicker, then it would be the green tube light. This solution is accounting for that the purple color is on the screen constantly even without the DVD player on. Get back to me if you need further assistance. There are other causes but you must eliminate the easiest possibilities first.
  • Lyle Siemens
    Lyle Siemens Nov 07, 2007
    Yes, replacing the lamp should fix your problem. Good Luck
6ya staff
SOURCE:
I have colored spots appearing on my screen when the TV is on. The spots are 2 to 6 inches in diameter and always appear in the same locations at various places on the screen. The first spots I noticed...
the light engine (optical block) is failing. there are lcd panels and light filters in the light engine. the problem your having is that they over heated and the image is burnt into the lcd or light filter. my be caused by a failing fan or just it's life span. the lcd panel or light filter are done for. you can keep calling panasonic and bug them over and over and they may send you a new tv. sony sent me one after 5 phone calls. i had the same problem. hope this helps.
Jan 14, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
My PT-44LCX65 has been showing numerous color spots recently. In August, I noticed a dark green spot in the top left corner, and also a less visible maroon spot near the center. Today (12/16/2010) I'm...
THAT IS GOING TO MOST LIKELY BE A PROBLEM WITH THE OPTICAL ENGINE AND PANASONIC HAD SEVERAL MODELS THAT HAD PROBLEMS WITH EEPROM CORRUPTION THERE WAS A RECALL TYPE OF EXTENDED WARRANTY I SUGGEST CALLING PANASONIC THEY WILL SEND SOMEONE OUT TO FIX IT MOST LIKELY FREE OF CHARGE :)
Dec 17, 2010 | Panasonic PT-52LCX65 44" HDTV
Blinking red power button
How many times does the power indicator blink as thats a error code indicating which circuit has the problem.
Jun 01, 2010 | Panasonic PT-47WX49 47" Rear Projection...
I have a PT-47WX53 rear projection TV that has a 3-4 inch vertical bar that is in a purplish hue. Barely visible. Asking for suggestions of repair. Thanks.
There is one very common problem for this--the band of noise appears after the set is on for a few minutes but you have no picture?
Panasonic ECWF2474JSR C509 CAPACITOR .47UF 200V
SD TECH
Dec 28, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Blue & green star like spots on Panasonic rear projection LCD TV
The EEPROM needs to be reprogrammed. You should contact Panasonic customer care as they may fix this at no charge to you.
Jul 07, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT50LC14 Rear projection LCD - too much green
Had the same problem today. Thought is was my bulb. Replaced it but still had the color problem. Replaced the cables between cable box and TV and no more problem!
Jan 22, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Vertical green lines
Call where you bought the TV. This is not normal for an LCD TV. They should exchange it only being a week old.
Jan 20, 2008 | Televison & Video
Panasonic PT 44LCX65 model
I also have this problem. TV is 2 years old. Service tech says the repair will cost about $600 per spot. I have 4 spots
Oct 30, 2007 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television Logo
233 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
