Question about HP Photosmart R725 Digital Camera
Dont know how to Reset
When i press power/on, a sign comes out saying "Camere has experience an error..... Please reset your camera."  How do i fix this?  I tried removing the battery but it didn't work.
Posted by Needy Manny on
  • 1 more comment
  • Anonymous Dec 12, 2007
    Camera says it needs to be reset, tried to remove battery but didn't work. When I zoom it is blurry.
  • Anonymous Dec 29, 2007
    I received an error message and it said to reset the camera. I have tried resetting it, but it still does not work. Now I don't even get the error message; it won't do anything.
  • halliew09 Dec 31, 2007
    When I try to turn my camera on, a red screen comes on that says, "unexpected error occured, please reset your camera.
Anonymous
Go to this site. I had the same problem-good luck
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00743921&lc=en&cc=us&dlc=en&product=1154651
Posted on Oct 27, 2007
I have a Canon PowerShot A430 camera. When I turn it on, the lens doesn't open and it shuts off. The message on the screen says " Lens error, restart camera." Please advise. Thanks
The Lens Error is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
You can reset the Camera back to factory default by performing the following steps:
Press the power button.
Press and hold the MENU button for more than 5 seconds. Default Settings will get displayed.
Use the arrow buttons to select OK and press the FUNC./SET button. This will reset all the settings back to factory deafult.
This should resolve the issue. If the issue persists, service may be required.
Thanks for contacting FixYa
Aug 10, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
Camera will not come on, it says "turn the power
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks for contacting FixYa.
Jun 19, 2011 | Sony Cybershot Dsc-w290 W230 W220
When i switch on camera an error camere moudule is not ready error appears
try to master reset or factory reset and see its work or not
Apr 16, 2010 | LG KG300 Cellular Phone
My printer canon pixma MP140 All-in-One is not printing! The light in B keeps flashing and its says E4! whats the problem?
Hi there you try.
Canon printers MP 160 AND MAYBE OTHERS
A) E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
B) E27 - it is code for reset absorber (EEPROM reset or Waste
ink counter reset) and follow the described below
procedure:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again.
Only in B) case you can enter into "service mode", in A) case or if have e.g. paper jam, or another error you CAN'T enter
the "service mode"
Try it
Anonymous see A) case: E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Sep 28, 2009 | Canon PIXMA MP150 All-In-One InkJet...
"lense error, restart camera"
on the camera bottom by the battery theres is a little niddle size reset button press it wit niddle when camera is on then it will restart to factory setting you can try more then ones pushing it.please leave comment,vote,note.thankyou
Sep 13, 2009 | Canon PowerShot A470 Digital Camera
When i try to download the pictures from the camera getting the error "there are no images in the camera or memory card that match downloand conditions" i am able to view the picturs in the camere
I don't know what kind of camera you have but the ones I have used allow you to tag photos on the camera. Then tagged photos can be downloaded via a setting "download only tagged".. or even "download only photos not already downloaded". Try scrolling through your menus and checking for a setting like that.. worst case, look for a camera reset in the menu and reset all the settings.
Jul 07, 2009 | Cameras
I want a solution for a Sharp AR - 287 Digital Image problem
H-4 is an error code for the fixing assemblyand needs to be reset thru a simulation code, sometimes a power flucuation can cause this error and therefore may not need parts.
press #
press *
press clear
press *
when it is done properly the display will go blank
then enter 14
then press the start key, turn the machie off and then back on.
If the code comes back you'll need something for the fixing assembly
Good luck
Bob
Apr 27, 2009 | Sharp Office Equipment & Supplies
If the screen states E3, what does this mean and how can I fix it
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Perform these steps to reset the EEPROM
button pressing
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Press the reset switch
Same "Push the reset button problem in panasonic gs 200 camera. i turned it upside down but it didnt worked out. its an expensive camera please please please tel me how to fix "Press the reset switch" problem
Dec 26, 2007 | Panasonic NV-GS11B Mini DV Digital...
Camera restart?
Have u tried a hard reset on their camera by removing the main power batteries for 60 seconds and the reinserting them as if it were the first time power up. This may not fix your particular problem, but when the processor that runs all of the electronic features of the camera gets confused, this is the best way to clear its confusion
manual page 114....
tel me if this works
Sep 26, 2007 | Canon PowerShot A540 Digital Camera
HP Photosmart R725 Digital Camera Logo
52 people viewed this question
Top HP Cameras Experts
Lawrence Oravetz
Harrie
Harjeet s. bola
Harjeet s. bola
Are you a HP Camera Expert? Answer questions, earn points and help others
