2001 Jeep Grand Cherokee Radiator Fan Doesn't run
Have you confirmed the fan has a good ground, sounds like you have eliminated the issue of 12 volts, when you turn on the fan then the AC does the compressor run? if the compressor runs pull the plug to the fan motor and check to see if has 12 volts with a test light, wait for moment because the fan may not run until the AC system pressure reaches a certain pressure point, this means that even though the compressor is running the fan may not always run, There is a quick test for the fan circuit, disconnect the fan sensor at the thermostat housing, the fan should come on, this is failure mode, so if the switch goes open the fan will run to keep the engine from overheating , let me know after the tests are run.
