Freezer temp drops to 14, fridge drops to 31, both on medium settings, then compressor doesn't come on again unless I set switch thermostat to off and slide back to medium. Same cycle repeats.
SOURCE: GE Profile fresh food getting TOO cold
Faulty air damper is the usual cause , or possible sensor fault
SOURCE: Inglis Fridge model# IRT184300, warm fridge, cold freezer
There is a fan in the top of the refrig that is not turning. Ck for that fan and pos. ice build up in between.
SOURCE: ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
SOURCE: GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
A week of 0-10 deg highs this week, freezer warms up to 30 after about 12 hrs and fridge at about 39. I replaced defrost heater and defrost timer a few months back and that solved the freezer fine fridge too warm problem. This is different and prob noticed about 1-2 weeks ago when musty water smell started appearing. Foods were somewhat defrosted up high but bag of ice down low was fine. Compressor runs 30-40 mins at start of rest/cooldown cycle.
After a few more weeks, fridge seems to operate normally or a few degrees colder than based on it's setting. Freezer cools down to around 10 at it's lowest point. Seems to come on when needed. I am curious to know how low Freon leads to this cycle.
