Hi Rana, I am happy to assist you!
Generally, error code E11 means that your washing machine is taking a long time to fill (or is continuing to fill).
Is the incoming water flow normal? If it is, does the fill water continue to enter your washer? If yes, disconnect power from your appliance. Did the water fill stop? If so, a service technician may need to check the pressure sensor or switch to determine if it needs replacement.
If your water flow is abnormal, double-check water faucets to ensure they are in the "on" position. If on, your incoming water pressure may be above 30 PSI and could need adjusting. Check for any kinked or blocked water hoses or clogged water screens. If you've cleared the water screen and/or unblocked any kinked water hoses, and the problem still persists, it could possibly be a water inlet valve assembly.
If you have checked all of the above, the unit may need a main control board replacement. I would recommend contacting a qualified service technician to further assist you in diagnosing this issue.
