Video Cameras Logo
Question about Video Cameras
Sony manuals I use a sony monitor model: sdm-HS95P with a mini mac and need to know how to remove the i information display on the screen
Posted by sylvia Rheker on
Jerry Thomas Hutcherson
    New Friend:
  • 153 Answers
1helpful
Dear Sir I have a problem with my SONY SDM-HS95P/B 19" LCD Monitor. When I turn on the screen the desktop appears for several seconds and than it became black as when you turn off, although the...
Check the caps on the power supply/inverter board first to see if it has any one of them with bulging/leaking tops or bad bottom seals.
See my pictures here (the caps in questions have my red marker on them).
http://s807.photobucket.com/albums/yy352/budm/SONY/Sony%20SDM-HS95P/
To have it repair will not be worth it, you can DIY repir if you have all the needed tools and know how to solder.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Looking for windows 7 driver for SDM-HS95P monitor tq
(If this does not explain enough for your issue, please take a few minutes to clarify the specific problem regarding this specific monitor style and Windows 7).
Being that this is an older style monitor, drivers may not be available for a newer operating system, (such as Windows 7). Here is the link to the sony drivers download page:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=SDMHS95P
The newest supported operating system is Windows XP.
The generic monitor driver for windows 7 should pick up this monitor without any need for specific driver installation. Just try plugging it in and it should register automatically.
Sudden white screen
Check for 5 or 12vdc feeding the T-CON board, try reseating the connectoe to the T-CON board.
Basic LCD monitor troubleshooting guide:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Please post back what you find.
2answers
ETI information box appears on SONY SDM-HS95 monitor repeatedly
You might try checking you monitor setup, you should be able to shut it off by unckng the proper box
Black screen with message about no input signal
might be something wrong with your monitor's data cable
Sony LCD flat screen monitor
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
Vista Drivers
http://esupport.sony.com/US/perl/swu-download.pl?mdl=SDMHS95&upd_id=2252&os_id=4
sony gives this drivers that supports most windows version,try it with vista
Pop up menu won't go away.
If you can do the factory reset in the pop up menu, try it. You might have to try with another power supply, cord, or computer and check where the problem is.
Top Video Cameras Experts
Tony Parsons
Tony Parsons
Tom Chichester
ray gallant
Are you a Video Camera Expert? Answer questions, earn points and help others
