Question about 2wire (2701HG-B) Wireless Router
I38hg wps button - 2wire (2701HG-B) Wireless Router
I am trying to connect my canon pixma 452 printer to my samsung tablet. Where is the WPS button ?
WPS Connection Method Before we start, there are some conditions that must be met in order to use the WPS push button method:
  • The access point must have a physical WPS push button available. Please check with your device's user guide for details. If the WPS push button is not available please use the instructions on the Standard Connection Method tab.
  • Your network must be using the WPA (Wi-Fi Protected Access) or WPA2 security protocol. Most WPS enabled access points use this protocol.
Step 1 1. Press the [Setup] button (A) on the printer.
Step 2
1. Select [Wireless LAN setup] and press the [OK] button.
The blue Wi-Fi lamp (A), will light up when the wireless connection is enabled.
The printer will now automatically search for access points supporting the WPS feature
Step 3
The display on printer should be as shown below:
(The message will read: "Press WPS button about 5 sec. and press [OK] on the device)"
1. Press and hold the [WPS] button on the access point.
For exact instructions on starting WPS on your access point, please refer to its user guide.
2. Press the [OK] button on the printer within 2 minutes.
The blue Wi-Fi lamp on the printer flashes while searching for or connecting to the access point.
Once connected, the following screen will appear. Press the [OK] button.
If another screen appears, please refer to "troubleshooting" in the user guide.
This concludes the WPS setup procedure.
Please now proceed by installing the software to make the most out of your PIXMA MX474.
  1. If you do not have the installation CD that came with your product, please download the manuals and software.
If the WPS wireless setup is still failing after following this guide, please Contact us for further assistance. 1 888 224 4280
Aug 16, 2018 | Canon Office Equipment & Supplies
Where is wps button?
About 49,500 results (0.39 seconds) Search Results
    What is WPS and how do I use it to set up the printer on the ...
    https://support.usa.canon.com/kb/index?page=content&id...
    Jan 15, 2016 - Use the , , and keys to select WLAN setup , then press the OK button. The printer will search for Access Points / Routers. If a WPS-compatible ...
    where is the WPS button? - Canon Community
    community.usa.canon.com/t5/Printer...Support/...WPS-button/td.../8893
    Dec 27, 2012 - Hello dmlarsen. The WPS button is not on the printer. This button would be located on your router itself. If your router does not have a clearly ...
    How to perform the wireless LAN setup using WPS connection
    support-th.canon-asia.com/contents/TH/EN/8200685600.html
    Dec 10, 2009 - Press and hold the WPS button on the access point (for about 5 ... If the Printer Connection screen appears instead of the screen above, the ... images for Printers & Copiers Where is wps button
Jan 23, 2016 | Office Equipment & Supplies
I cannot find my WPS button on my Wifi printer. I have pressed WPS on router but no different
Dec 27, 2012 - It asks for me to push the WPS button, but can't find? ... Now I am afraid to unplug the printer and move it back to my desk because it will ... starting only 2 days back, it was daily "dropping" my wifi connection with my MacBook.
WPS access point - Canon Community
community.usa.canon.com/t5/Wireless.../What...WPS.../11819
Jan 19, 2013 - What and where is the "WPS access point" button required to set up wififor the ... What and where is the "WPS access point" reqired to use wifi for the MX432printer .... My WPS button is on my the back of my router (blue button) ... I have a tp-link model tl-wr841n and I can't find the access point in the router ...
Connecting your HP wireless printer ' Wireless Printing ...
Nov 19, 2015 | Computers & Internet
Can a WiFi repeater with WPS connect to a Wireless router without WPS ? I can't seem to get them to connect to each other via WiFi
WPS only works with client Wi-Fi devices that have a WPS button.
Your router does not have it, so it does not work.
Jan 06, 2015 | Computers & Internet
To adapt N300 Wireless Adapter, I need to press the WPS button on wireless router or gateway. Unable to locate WPS button.
The reason you may wish to press a WPS button is to connect to a WiFi network. The WPS button will be on the router, not on your computer. If no WPS button on the router you will need to enter the WEP/WPA password to connect to the router.
Nov 14, 2013 | Samsung Computers & Internet
Wps button
The front of your Actiontec modem has a button and light for Wi-Fi Protected Setup (WPS). If that button was pressed or the WPS process was started, that button may light up or blink.
Aug 16, 2013 | D-Link DIR-625 (790069292637) Wireless...
Wps light blinking
CALL YOUR ISP FIRST.
wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections. Some of NETGEAR's products use the name Push 'n' Connect for WPS. To use WPS, your product must support WPS and be compatible with WPA security. WPS can automatically set up a random network name (SSID) and strong WPA wireless security for wireless routers, access points, computers, adapters, Wi-Fi phones, and other electronic devices. WPS lets you use a push button or enter a personal identification number (PIN) instead of manually entering a network name (SSID) and password:
  • Push button. The WPS button is either on the product or a clickable button on a wizard or utility screen.
Jan 22, 2013 | Netopia Motorola 2247-n8 Wireless Dsl...
Where is the wps button
https://www.manualslib.com/manual/382487/D-Link-Dcs-932l.html?page=13
Apr 08, 2017 | Motorola Computers & Internet
2wire (2701HG-B) Wireless Router Logo
70 people viewed this question
Top 2wire Computers & Internet Experts
efs_perpends
efs_perpends
Mike
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
