No solution from me, Note: Sounds like your pretty familiar with the Positive crankcase ventilation (PCV). You said the valve is pulling a vacuum I am assuming it is from the intake manifold side correct? With the PCV was working sure seems like it would keep the oil from coming out of the dipstick tube. I am stumped as well, sounds almost like too much blow by from the cyclinders you already stated that with the possible broken compression rings?
SOURCE: engine blowing oil from oil filler cap
I had the same problem. I changed the pcv valve and checked the hose. It still did the same thing. Then I checked the metal tubing that the hose connects to and found it was full of hardened gunk. I sprayed PB Blaster into the tube let it soak for awhile. Then took an old choke cable, put it on a drill and ran it into the tube like a drain snake. It took a while of doing this over and over but eventually got it cleared out. Now, no more oil all over the engine and hood compartment.
SOURCE: Oil blowing out of the dipstick tube.
On top of the valve cover there is a fresh air breather unit. Make sure the breather unit is not plugged.
Also the fixed orifice PCV should be clear. Find a tool that will go through the orifice and make sure it is clean.
Remove the vacuum hose and check it for cracks or internal damage. With the engine running, make sure you have vacuum through the hose.
Let me know when your finished cleaning the crankcase breather system.
Regards,
SOURCE: 1994 jeep YJ Automatic transmission does not shift
For your sake I hoping its a shift solenoid. Yes its in the valve body and there is some transmission surgery involved but its not that pricey. Otherwise it could be the shifter , manual shift valve, 3rd gear linkages etc. This is major tranny surgery. keep me posted.
