Washing Machines Logo
Question about Bosch Washing Machines
Does the Bosch Exxcel 7 1200 Express have a child lock function?
We have a 5 year old Bosch Exxcel 7 1200 Express washing machine but no longer have the manual. We'd really like to activate the child lock function as our 10 month old keeps pressing the buttons mid cycle. Anyone able to help?
Posted by Hannah Cartman on
MAX POWER
    Sergeant:
  • 419 Answers
Try the manufactures website for free manual download
Posted on Dec 09, 2013
5 Related Answers
Anonymous
  • 38 Answers
SOURCE: Washing Machine Will Not Drain
you have got a blocked filter or pump the filter is located on the right hand side at the front of the machine down the bottom behind the plinth you can drain the water from there as well by pulling the small grey hose out pull the plug out of the end and place in a small bowl good luck when the water is out you can check the pump impeler as well clean the filter houseing and put it back all should b well unplug the machine b4 u start work
Posted on Sep 04, 2007
Anonymous
SOURCE: my bosch exxcel washing machine
how to remove the drum
Posted on Oct 04, 2008
Anonymous
  • 43 Answers
SOURCE: bosch exxcel 1200 express
need more info what point in the wash does it start to display the code
Posted on Nov 11, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: I have a Bosch Exxcel 1400 S Express which blew
There is no internal fuse in the washer to replace.
If you have replaced the fuse, make sure that is is a good one.
If you are satisfied that you have power to the washer, then I'm afraid it sounds quite serious.
Trust this helps.
Posted on Dec 05, 2009
prem mathew
  • 662 Answers
SOURCE: bosch classixx 1200 washing machine stalling mid-cycle
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your pump/filter is plugged. (E4) There is a round door on the lower front of the washer. There is a small hole near the door. Put a small screwdriver blade in the hole, push in just a little, and you can rotate the door clockwise, the door will come out and you can get to the problem. When the water is drained in machine the door is open able.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter. When you unscrew this, all the water left in the washer will spill out onto the floor. Use a plastic bag to catch this or a small pan.(later models have a drain hose?) The black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find the source of your clog. Remove it, clean out, screw the black connector back in. You can check with rinse, if you want to make sure there are no leaks. Put the door back on and rotate. I will try to come back to you re. the wash, wash.
Pl rate me 'very helpful' for the free help, thanks!
Posted on Jun 17, 2010
I have a Bosch Exxcel 7 1400 express, had F21 error which I cleared but now when set to wash, water comes in but the drum doesn't move.
F21 refers to the carbon brushes in the motor so price new brushes - if you are handy they are easy to fit and not expensive - but if you can't do it yourself i personally wouldn't spend too much on repairing a 5 year old machine
I think the child lock as been operated on my washer
Select a cycle (ie dial not on OFF) press start button until lock goes off.
1helpful
Bosch exxcel maxx washing machine showing key
The key indicates that the child lock has been set, to deactivate it you usually have to hold the start button for approx 5 secs.
4helpful
CHILD LOCK PROBLEM
hold start button for more than 5 secs will disable child lock. same again to turn back on.
3helpful
Trust this helps.
5helpful
3answers
USER MANUAL FOR BOSCH EXXCEL 1400 EXPRESS WASHING MACHINE
just go a bosch washing machine exxcel 14 express cant get it to work can anyone help i dont have the user book my email is [email protected]
14helpful
Machine won't wash because 'child lock' is on
Holding down the Start button for over 5 seconds turns the child lock on and off.
3helpful
Bosch exxcel 1200 express
2answers
My bosch exxcel washing machine has the child lock on how do i take it off
Type in Bosch exxcel (and the model) Instruction manual... into the top right hand address bar on your pc and scroll down the list. You will find all the instruction manuals you need online.
sue
Open Questions:
Top Bosch Washing Machines Experts
Marvin
Marvin
Steve
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
