Spectra Ford F-150 96 95 94 93 92 F-250 F-350 F Super Duty Parts Car Auto 1996 1995 1994 Logo
s
scott brierly Posted on Dec 08, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wiper control module location
Replaced wiper motor now the wipers are either on or off intermittent not working and whe I push the washer button the only way to shut the wipers off is to shut the truck off
Daniel Mc Entee
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 1,449 Answers
  • Posted on Dec 23, 2013
Daniel Mc Entee
Master
Level 3:
Renaissance:
Answers
1449
Questions
0
Helped
275383
Points
3556
Change the wiper relay.
2answers
2002 Corvette Wipers wont shut off
If the windshield wipers on your 2002 Corvette won't shut off, it could indicate a problem with the wiper control switch or a malfunction in the wiper motor circuit. Here are some troubleshooting steps you can try:
  1. Check the wiper control switch: Ensure that the wiper control switch is in the "Off" position. Sometimes, the switch can get stuck or malfunction, causing the wipers to stay on. Try moving the switch back and forth a few times to see if that resolves the issue.
  2. Inspect the wiper motor relay: The wiper motor relay controls the power supply to the wiper motor. If the relay gets stuck or fails, it can cause the wipers to stay on. Locate the wiper motor relay in the fuse box or relay panel and try replacing it with a known working relay of the same type to see if that resolves the issue.
  3. Check the wiper motor circuit: The wiper motor circuit may have a short or an electrical problem that is keeping the wipers engaged. Inspect the wiring harness connected to the wiper motor for any signs of damage or loose connections. Use a multimeter to check for continuity and proper voltage in the circuit. If you are not familiar with automotive electrical systems, it is advisable to consult a professional technician or a qualified electrician.
  4. Disconnect the battery: As a temporary solution, you can disconnect the negative terminal of the car battery to stop the wipers from running. This will disable other electrical components as well, so it's recommended as a temporary measure until the issue can be properly diagnosed and repaired.
2answers
Hi have an 07 trailblazer. The rear wiper motor only works if you unplug it and then plug it back in.
Sounds like a wiring problem:
1. One of the wires attached to a pin in the connector attached to the wiring at the motor (not on the motor) may be corroded or have come loose, making intermittent contact, or
2. One of the wires in the harness between the motor and the switch is crimped somewhere around the tailgate and is intermittently opening, or
3. A bad motor ground wire connection at the tailgate.
Wipers not working 2009 Pontiac G6 Wiper Motor where is the fuse located so that I can check it? Before I replace the motor
Just replacing parts isn't the way to fix this problem , viewing wiring diagrams too see what all is involved in making the wipers work is . Then using a digital volt ohmmeter to test electrical circuits . Also looking at factory service info. to see how it's suppose to work.
Free wiring diagrams here http://www.bbbind.com/free-tsb/ Enter vehicle info. year , make , model an engine size . Under system click on body & accessories , then under subsystem click on wiper/washer . Click the search button ,then click the blue link. Looking at the wiring diagram i see two fuse's an two relays that are controlled by the BCM - body control module . Also hooking up a scan tool that can read BCM DTC'S - diagnostic trouble codes could be helpful . The wiper switch is a input to the BCM - the BCM will energize the relays to turn on the wipers.
Wiper/Washer System Components
The Wiper/Washer System consists of the following components:
• Windshield wiper/washer switch
• Body control module (BCM)
• Wiper 1 relay
• Wiper 2 relay
• Wiper diode
• Windshield wiper motor
• Windshield washer pump
• Windshield washer nozzles
• Windshield washer solvent container
• Windshield wiper arm and blade assemblies
• Windshield wiper transmission
• WIPER/SW 10A fuse
• WIPER 25A fuse
Wiper/Washer System Description
The body control module (BCM) controls wiper motor low speed operation. The washer pump and high speed operation are controlled directly by the wiper/washer switch. The windshield wiper/washer switch supplies voltage on the signal circuits to the BCM for windshield wiper/washer operation. When WASH, MIST, DELAY, LOW, or HIGH is detected, the BCM energizes the wiper 1 relay by suppling voltage to the relay coil. This allows battery voltage from the WIPER fuse to flow through the relay switched input then through the contacts and out the relay contacts to the wiper 2 relay switch contacts. Since the wiper 2 relay switch contacts are normally closed to the low speed circuit of the windshield wiper motor, the motor will operate at low speed.
DTC B3715 02: Front Wiper Relay Drive Circuit Short to Ground
DTC B3715 05: Front Wiper Relay Drive Circuit Short to Battery or Open
1helpful
2008 dodge grand caravan front wipers won't go all the way up
Do you know anything about automotive electronics ?
FRONT WIPER/WASHER SYSTEM
The windshield wipers can be operated with the windshield wiper switch when the ignition switch is in the RUN or ACCESSORY positions. The wiper/washer switch is integral to the multi-function switch. It is a resistive MUX switch that sends inputs to the Steering Control Module (SCCM) then across the LIN bus to the Cabin Control Node (CCN) and from the (CCN) across the CAN Interior High Speed bus (CAN I-HS) to the Totally Integrated Power Module (TIPM) to operate the wiper/washer system.
The wiper motor has permanent magnetic fields. The speeds are determined by current flow to the appropriate set of brushes inside the motor. The current flow is controlled by the multi-function switch. The high speed/low speed relays are located in the Totally Integrated Power Module (TIPM), and cannot be serviced separately. The speed sensitive intermittent wiper is controlled by the TIPM. When in the intermittent mode, and the vehicle traveling greater than 10 mph, the delay between wipes will range from 1 to 18 seconds. With the vehicle traveling less than 10 mph, the time delay doubles to a delay range of 2 to 36 seconds. The wiper arms will park at the base of the windshield just above the cowl cover after the wiper switch is turned OFF. The washer pump for the front washer system is shared with the rear washer system by the use of a reversible washer pump motor. The windshield wiper motor and linkage is located in an integral wiper unit at the rear of the engine compartment. The wiper unit must be removed to gain access to the wiper motor.
For a complete wiring diagram Refer to the Wiring Information.
  1. When Monitored: With the ignition on.
  2. Set Condition: The Totally Integrated Power Module (TIPM) detects a short to ground on the Wiper Park Switch Sense circuit.
No
  1. The condition that caused this symptom is currently not present. Check for an intermittent condition by inspecting the related wiring harness for chafed, pierced, pinched, and partially broken wires. Also, inspect the related connectors for broken, bent, pushed out, spread, corroded, or contaminated terminals. Repair as necessary.
  2. Perform the BODY VERIFICATION TEST - VER 1. (Refer to 28 - DTC-Based Diagnostics/MODULE, Totally Integrated Power (TIPM) - Standard Procedure)
No
  1. Go To 3
No
  1. Repair the (W7) Wiper Park Switch Sense circuit for a short to ground.
Your best bet , take it to a qualified repair shop .
1helpful
WHERE IS THE WIPER/WASHER FUSE LOCATED ON 2007 PONTIAC TORRENT
In the under hood fuse box , should have diagram inside the lid . Front wiper's or rear ? Front fuse # 36 - 25 amp. Plus Two relay's PCB hi and Wiper PCB relay . Wouldn't think this being fuse problem . Wiper switch , motor etc... The wiper's are control by a computer . BCM - body control module .
The windshield wiper/washer system consists of front and rear wipers. The front and rear wipers are operative when the vehicle is in accessory or run. The front wipers have 4 different modes: Mist, Intermittent, Low, and High. When the front wipers are in the intermittent mode, there are 5 delay modes to chose from, commanded by the windshield wiper washer switch through the body control module (BCM). The rear wipers has an only one mode.
If the fuse is bad , could have a short to ground or wiper motor pulling to much current (amps) . Fuse's don't just blow for no reason ! Could also have DTC'S - diagnostic trouble codes stored in the BCM .
DTC B3715
DTC B3873
DTC B3875
DTC B3922
The body control module (BCM) controls the wiper motor based on input from the windshield wiper washer switch. The BCM monitors the wiper washer switch through three separate signal circuits and a ground circuit. The windshield wiper switch high signal circuit is used to determine high speed wiper operation, the windshield wiper switch low signal is used to determine low speed, intermittent, and mist operation through the use of a resistor ladder, and windshield washer switch signal circuit is used to determine washer operation.
The BCM controls the windshield wiper motor through two output controls, controlling two different PCB relays which control the desired wiper speed, high or low.
DTC B3922 00: Front Wiper Function Select Circuit
The PCB relay's are non- servicable , replace fuse box . Soldered in Your best bet mit be to take it to a qualified repair shop .
Looking for the fuse for the wiper motor 2008 chevy impala
WPR fuse 25amp under hood fuse box .
• Wiper PCB relay
• Wiper high PCB relay
• Windshield washer fluid pump
• Windshield washer fluid level switch
• WPR fuse 25 A
• WSW fuse 10 A
This is more then likely not a fuse issue !!!!!!!
Low Speed Operation
When the wiper switch is in the low speed position, ground is applied through the switch internal resistor and the wiper switch low signal circuit to the body control module (BCM). In response to this signal, the BCM energizes the WIPER PCB relay by applying battery voltage through the wiper relay control circuit to the coil side of the relay. This allows battery positive voltage from the WPR fuse to flow through the switch input side of the WIPER PCB relay and out to the switch input side of the WIPER HIGH PCB relay. Since the wiper high relay is de-energized and its switch contacts are normally closed to the low speed control circuit of the windshield wiper motor, the motor will operate at low speed.
Wiper motor low speed operation and the wiper PCB relay can also be commanded ON/OFF by using a scan tool. Refer to Control Module References.
The PCB relays mentioned above are soldered right into the circuit board inside the fuse/relay block under the hood . There are alot of reasons for the wipers not to work ! The fuse could be blown but fuse's don't just blow for no good reason , short to ground , low resistance high current flow etc.... Intermittant !
Power and Grounds
With the ignition in the ON position, accessory voltage is supplied through the 25A WPR fuse to the WIPER PCB relay, the WIPER HIGH PCB relay and the WS WASH PCB relay that are all located in the underhood fuse block. Refer to Wiper/Washer Schematics.
G200 provides ground for the windshield wiper motor and the WIPER PCB relay. G100 provides ground for the windshield washer fluid pump and the windshield washer fluid level switch.
1helpful
2answers
Windshield wipers
Would need to scan vehicle to insure the wiper speeds are controlled by the General Module or a wiper intermittent relay....if relay...would locate and replace...if general module.....a reprogram or software update could be in order...possibly replacement.
Scott, Porsche Master Tech 35 years
2helpful
What relays are there for the intermittent wipers and where are they located on a 1999 Ford Taurus?
the intermitent works off of the (gem) generic electronic module which controls the wipers. if wipers working except the delay cycle replace the module. the relays are located in the engine compartment . wiper park relay- wiper hi-lo relay- washer motor relay. fuse in fuse panel under driver side dash panel.
2helpful
My windshield wipers wont turn on
This information is out of my manual, I hope it helps you, Ian
WIPERS/WASHERS
DESCRIPTION
in the RUN or ACCESSORY positions. The windshield
wiper system is protected by a 30 amp fuse (9)
located in the Power Distribution Center (PDC) part
of the Integrated Power Module (IPM) in the engine
compartment. The wiper/washer switch is integral to
switch that sends inputs to the BCM to operate the
REAR WIPER/WASHER SYSTEM
The rear windshield wiper and washers can be
operated when the ignition switch is in the RUN or
OPERATION
The windshield washer circuit is protected by a 9
amp PTC located in the Junction Block. The wiper
by the multi-function switch stalk mounted
wiper switch, high speed/low speed relays located in
the Power Distribution Center (PDC) part of the
Integrated Power Module (IPM) in the engine compartment.
controlled by the Body Control Module (BCM). The
intermittent mode, with the vehicle traveling greater
than 10.4 mph, has a range of 0.5 to 18 seconds.
With the vehicle traveling less than 10.4 mph, and
the time delay is not adjusted, time delay doubles to
a range of 1 to 36 seconds. The wiper arms will park
WIPERS/WASHERS (Continued)
When continuous rear wiper operation is required,
the Body Control Module (BCM) will provide ignition
ON voltage to the rear wiper motor. When the wiper
switch is turned OFF, the BCM provides circuit
ground to operate the motor until the wipe cycle is
complete and the wiper arm returns to the base of
the rear window.
When intermittent rear wiper mode is selected, the
wiper motor will cycle every 7 seconds. The intermittent
delay time is also adjusted based upon vehicle
speed. With the vehicle traveling greater at 50 mph,
the cycle changes to every 5 seconds. DIAGNOSIS
AND TESTING
DIAGNOSIS AND TESTING - FRONT WIPER
SYSTEM
The windshield wiper system operates in several
modes:
† Low and high speed normal wipe
† Speed sensitive intermittent wipe
† Wipe after wash
† Pulse wipe
† Park (switch OFF)
The windshield wiper circuits are continuously
monitored and controlled by the Body Control Module
(BCM). If a problem occurs in the electronic components,
wiring, switch (except integral motor park
switch) and wiper motor a Diagnostic Trouble Code
(DTC) will be stored in the BCM memory. DTC’s can
be retrieved using a DRB IIIt scan tool. Refer to the
proper Body Diagnostic Procedures manual for DTC
descriptions and retrieval information.
The windshield wiper park switch and circuit is
monitored by the BCM. The park switch and circuit
can be tested using the Wiper System Diagnosis
table.
DIAGNOSIS AND TESTING - REAR WIPER
SYSTEM
The rear window wiper system operates in several
modes:
† Continuous wipe
† Intermittent wipe
† Wash
† Wipe after wash
(DTC) will be stored in the BCM memory. The
DTC(s) can be retrieved using a DRB IIIt scan tool.
Top Spectra Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Spectra Car Audio and Video Expert? Answer questions, earn points and help others
