Question about JVC MX-J30 CD Shelf System
Jvc mx j30 says no disc how to fix
The cd will not work says no disc
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: JVC MX-KB30
Have it first cleaned by a cd disc cleaner or if you are familiar with cleaning the lens manually im sure that will work...or try inserting an original cd's,if it works with that find the solution to the settings of your device...
Posted on Sep 23, 2007
Anonymous
  • 319 Answers
SOURCE: Error message No Disc
Unit has bad disk t-table motor
Posted on May 07, 2008
Anonymous
SOURCE: JVC Stereo won't open cd tray
take off the cover and get whatevers jamming it out mine did the same thing
Posted on Jul 30, 2008
ABRsvcs
  • 4234 Answers
SOURCE: I have discs in my cd player but it says NO DISC.
The "no disc" messing indicates that the disc is not readable. This can be due to a dirty lens on the optics or defective optics. If you can gain access to the CD section, try cleaning off the lens of the optics assembly using a cotton swab and alcohol. Let me know if that does not resolve the problem.
Dan
Posted on Dec 02, 2008
Anonymous
  • 113 Answers
SOURCE: How can I modify my audio system as a Mp3 player
Hi sorry cant be modified to do but what you could do is use an external player and plug it into the AUX input on the back
Hope that helps
Posted on Jul 22, 2009
Where can I purchase an fm aerial for this jvc
Just about any electronics or big box store (Walmart, Target, etc.) will have an FM antenna. They will be in the electronics section.
Mar 18, 2015 | JVC MX-J30 CD Shelf System
No power not even light but power is going to transformer also touch the metal cover with a phase tester and it lights up (only just though)..jvc mx-j30
hello you may have ac power but no dc power take the cover off and have a look for any swollen capacitors or components that might be burn't
regards
shaun
Feb 10, 2010 | JVC MX-J30 CD Shelf System
No power, sometimes working
please check the input voltage and adjust it
Feb 08, 2010 | JVC MX-J30 CD Shelf System
How do i connect my mp3 player to my jvc stereo
If it has a aux input at the back you can get a dock and that will let you plug it into your system.
Jan 23, 2010 | JVC MX-J30 CD Shelf System
Disk pops-up and blocks halfway when booting
Probably a poor suggestion, but you may want to look for a reset button on the back or the front. It is usually recessed and about the diameter of a paperclip. The electronics may be "confused".
Jan 16, 2010 | JVC MX-J30 CD Shelf System
Hope that helps
Jul 21, 2009 | JVC MX-J30 CD Shelf System
JVC MXJ30 Compact Hi-Fi
Spares from JVC? Where's the cheapest remote? Where's the cheapest Service manual?
Mar 09, 2009 | JVC MX-J30 CD Shelf System
Unable to read any CD on JVC MX-J30 CD Hi-Fi
Failure of this laser is quite common giving a no disc message in the HiFi's display. A defective laser can also be responsible for an intermittent no disc message and general playability problems with CD discs. Part number Optima 7 / 7B Laser Assembly
Nov 11, 2008 | JVC MX-J30 CD Shelf System
When I put a CD in any tray of my JVC MX-J30, it tells me "No Disc". What is the problem?
It may need the lens cleaned. Try running a lens cleaning disc for about 20 to 30 seconds. If that does not help, you will need to take it in for service if you want it fixed. The most common repair for these with that error is the laser pick up going bad. It would probably cost about $125 to repair depending on the repair centers rates.
If I can be of any more help to you let me know.
Dave
Jul 04, 2008 | JVC Audio Players & Recorders
May 06, 2008 | JVC MX-J200 CD Shelf System
JVC MX-J30 CD Shelf System Logo
143 people viewed this question
Top JVC Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
