Question about General Electric WCVH6800J Front Load Washer
Spin cycle keeps restarting
Replaced faulty pump now spin cycle keeps restarting. Will spin just will not pick up enough speed. Bad motor or bad belt?
Posted by Nicholas Gehr on
flobb
  • 57 Answers
Likely to be motor, specifically the brushes. depends on how old the machine is. brushes are replaceable and tend to need replacing from4-5 years with some makes
Posted on Dec 08, 2013
2answers
Speed Queen Washer agitates and cycles appropriately but does not spin fast enough to properly get the water out of the clothes.
I hope that you ordered the correct part, Also there is an idler pulley that maintains the belt tension and that needs to be checked for proper tension.
2answers
LG WM2101H won't dry until many cycles
Won't dry? I guess you mean spin enough water out? Depending on age, warranty, It sounds like a worn or bad drive belt or possibly a problem with the discharge pump not working properly.
It spins during rinse cycle but the clothes don't spin dry. Still very wet, even after a second spin without any more water being added.
It may not be spinning fast enough. Is the agitator operating at normal speed?
Possible causes for slow spin are overloaded washer, slipping belt, bad bearings in the motor or clutch, or slipping clutch.
Another possibility is a problem with the pump, but I suppose you would also see some water left in the bottom of the machine in that case.
My WBXR1060TAWW GE washer is eating thru belts....I replaced one about 2 weeks ago and the new one is fraying badly. It looks like it's rubbing metal when going through the spin cycle... It all started...
tensioner pully could have bad bearing when ran gets hot and tries to lock up causing premature belt wear. spin all pullys with belt ff any hard to turn or so loose they might fall apart
2answers
Doesn't spin all the water out
sounds like the coupler that connects the motor to the transmission is going bad.  A $20 part
I have a problem with my washing machine..
Basic Washer Problems
No fill:
Bad water valve
kinked hoses
unpaid water bill faulty electronics. Overfill:
trash in water level switch tube
bad water valve
bad water level switch faulty electronics. Washes but don't spin:
bad lid switch
bad drive coupling or belt
bad motor faulty electronics Spins pumps but don't wash:
bad timer
bad motor
bad luck faulty electronics. Leaks:
bad hoses
bad pump
bad tub gasket faulty electronics. Fills washes but never advances:
bad lid switch
locked up pump
bad motor
bad timer faulty electronics. Goes through complete cycle but clothes soaking wet:
bad belt
bad pump
bad thrust bearing faulty electronics*. *electronics in appliances ****. My opinion.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Washer belt is loose, & seem to slip at start of spin cycle.
there are several drive belts for this model... check here to see if the one you are fitting is the correct one... also,is the tensioner siezed? causing the tension to be too slack therefore allowing the belt to shred at speed?
check here .. http://www.partselect.com/AppliancePartList.aspx?Brand=Admiral&Appliance=Washer&ModelNum=&Type=Belt&MinSize=U&MaxSize=U&Electrical=U&Metal=U&Plastic=U&OneColor=U&PageSize=15&FirstPart=1
Heavy Duty Speed Queen top loader, HA 4011-3062, with a slow spin
I have a related problem and I just learned on the net that the Vbelt is supposed to slip in "idle" mode while the water pump will do more work.
It is also supposed to slip slightly while speeding the spinning up so as to not cause motor overload.A kind of half clutch function that allows for slipping. This slipping is controlled by the tensioner.
My guess is that your machine's v belt slips too much and thus does not spin fast enough. You replaced the belts, I would look at the tensioner now.
5helpful
2answers
Whirlpool washing machine won't spin after rinse cycle
there is a coupling between the motor and transmission that has cracked. with the crack in the coupling the transmission cant spin as fast as the motor causeing the loud noise. replace coupling to solve problem
General Electric WCVH6800J Front Load Washer Logo
Top General Washing Machines Experts
Oloyede Monsuru
sheakhly
Level 1 Expert
Dan Webster
Dan Webster
Are you a General Washing Machine Expert? Answer questions, earn points and help others
