Aiwa F2000 20" TV Logo
Question about Aiwa F2000 20" TV
Dead set no sound picture tube totally blackout. unit goes while watching tv program
Posted by vicente miraflores on
    Top Expert:
  • Aiwa Master
  • 76,851 Answers
If the unit has shut down during watching a program, there are mainly to reasons. The first one is its EHT section, and the second one is its main power regulator section circuits. Contact any service technician. Troubleshooting to this kind of fault is somewhat skilled one. If you wish to get some details, check the site linked here. Pull up older posts. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service center.
Posted on Dec 08, 2013
2answers
The tv will turn on sound and picture.. then all a sudden, just sound no picture. I thought the batteries were dying in the remote, could this explain it?
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
often that *needs* to be done in a service center as there are some adjustments to be made after replacement; don't know about this particular TV model, but it's a common thing for the plasma TVs
I hope this will help to solve the problem....
1helpful
Sounds could be heared upon switching on of the set but the screen has no raster (means total blackout as if the unit were off. a small red LED located @ the front panel continuously blinks just like the...
Since you said the the pictur tube is glowing, your EHT system is OK.
After selecting a channel if sound is alright the TV up to signal
detection is working OK.
The problem now could be in video amplifier circuits. Check the grid
voltages of the picture tube.
Or switch off TV, and check the resistance values of the resistors
connected to the picture tube pins. Replace the defective resistor.
Check after removing one end of the resitor as it will misguide you if in circuit.
6helpful
3answers
Was watching tv all of sudden screen turned black, with audio...
i was watcing tv afeter a while i realized there is no picture but we have sound
SCREEN WON,T STAY LIT UNLESS I TOUCH IT
You are simply in blackout mode. This is so at night you aren't blinded by the glow of a screen. Here are instructions right from the manual to turn on or off.
Blackout Mode On and Off
When Blackout mode is turned on, the monitor display will turn off to
reduce power consumption.
This additional power enhances the sound quality.
1 Touch [VISUAL] on the main source screen.
The VISUAL selection screen is displayed.
2 Touch [OFF].
The backlit-display portion goes out.
3 Touch [OFF] again to cancel the display backlight.
To make the setting, set to “Setting the VISUAL Touch Button” (page
34).
If any button on the unit is pressed during Blackout mode, the
function will be displayed for 5 seconds to show the operation before
returning to Blackout mode.
While the backlighting is turned off, the function indicator
1helpful
Periodic tv screen blackouts
The problem is your cable box. I know you said you replaced it, but I work on TV's everyday and, sorry to say this but cable box HDMI outputs have serious issues, like no or intermittent sound and video. I have seen customers exchange their cable boxes 5 and 6 times and still have the problem. Your best bet is to use the component outputs of your cable box, visually you will not see a picture difference between component and HDMI when using a cable box. Your other solution is to get satellite; I have NEVER seen an HDMI issue with a satellite box
2answers
Onida Ky Thunder tv blackout
my onida ky thunder giving fault led blinking after plugin and after 5 second goes to stopped mode
Red picture
Assuming this is a TV with a picture tube and not plasma or LCD; I'm afraid that your picture tube is dying on you one electron gun at a time. From what you said your green electron gun is almost totally dead and the two remaining blue & green guns aren't far behind. Eventually you'll have no picture at all and I would estimate that to be about 6 more months but whatever the time eventually it will go totally black. These blackout periods will get longer and longer. The only way to fix your problem is a new picture tube but my will probably find it less expensive to just get a brand new TV set.
TV or Satellite Box Problem?
Do you have a VCR or DVD recorder? If yes, set it to record what you are watching. After a "blackout" rewind the tape and review it. If there is a blackout on the tape, the problem is the sallite box, if not, it is the TV! QED
Commercial skip/blackouts
Sounds like you're blessed to have a tv like that! Seriously: Some sets have settings that will cut down the sound during a commercial. Haveyou looked at your owner's manual? This tv may have setting to cut out the picture also when commercials come on. From a technical view point generally commercials have stronger signals than regular programming. This may be overloading your set. If this is the case, then you need to have it checked by good technician. A poorly operating power supply (not regulating properly) could possibly cause a problem like this. Also automatic gain control circuits could be not working properly. Stargazer
Sony KV-24FV12 Image intermittant Blackout
Hello Robert, the picture tube on your TV set is exausted. Please contact your nearest Authorized Sony Service for further help/advice. After all, Sony is a good choice. The next TV set you buy could be one of Sony-s Bravia LCD. Kind regards, Arpad
Top Aiwa Televison & Video Experts
Colin Stickland
Colin Stickland
Mike
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
