Question about HP Compaq Presario V2000 Notebook
Yahoo messenger i CANNOT SIGN INTO MY MESSENGER, IS IT DOWN?
  • shadi Dec 04, 2007
    I can't connet to yahoo messant ?
    the message is couldn't dll ...
    Scholar:
  • 193 Answers
What messenger
Posted on Oct 13, 2007
  • ramji duraiswamy Oct 13, 2007
    OK. First of all, this could just be due to the Yahoo servers being down or busy. They have been making a lot of changes to them in the last few weeks.
    However, YAHOO Messenger has been having many invalid login password problems lately. If you are unable to log in to Messenger but are able to log into your account to access information, mail, and My YAHOO then please visit the following web page and fill out the form to notify YAHOO so that they can fix your account as soon as possible. Be sure to mention that you can access all other areas of your account with the exception to Messenger.
    http://help.yahoo.com/help/us/mesg/mesg-...
    It may also help for you to clear your temporary cache, although from the sounds of it, the Yahoo servers are just temporarily down or busy.
  • ramji duraiswamy Oct 14, 2007
    have u tried this
6ya staff
SOURCE:
Tip
Yahoo Messenger can't sign in - Unable to Connect to Yahoo Messenger
If you are having trouble signing into Yahoo Messenger you should read this article for some Tips and Tricks to get signed in.
There are a couple of things you will want to check first as they are common causes for being unable to sign in.
1) Make sure your internet is working. The easiest way to do this is by trying to visit other websites. After you have tried to visit some websites(it is best to test sites you have never been to before) and you confirm your internet is working but still unable to sign in, then continue to the other tips.
If you can't connect to other websites, you can read my tech article on Resolving Internet Connectivity Issues - "Can't connect to the Internet"
2) Sometimes, Yahoo Messenger will be down completely for everybody on a global level. This can be caused by problems Yahoo may be having or just general technical maintenance. Your only option if this is the case is to wait until it is over. You can confirm the Yahoo Messenger status at the Yahoo Messenger Support page.
If none of the above are the issue then continue below with Advanced steps
1) This tip is a recommendation from Yahoo Tech Support
1. Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "Firewall with no proxies" option.
3. Select the correct Internet connection type and country from the pull-down menus.
4. Click the "OK" button at the bottom of the window.
5. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
6. Enter your Yahoo! ID and password and click the "Sign In" button.
The above configuration works in most situations. (However, if you connect in this way, you won't be able to use the Voice feature.) If this configuration doesn't work, follow these steps:
2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window.
3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
4. Enter your Yahoo! ID and password and click the "Sign In" button.
If neither of the above options work, you're probably behind a firewall or proxy server that requires you to enter its address. Follow these steps:
2. Enable the "Use proxies" option.
3. Enter your firewall or proxy server's address and port number. Contact your network administrator (if you're at work), or your Internet service provider (if you're at home) to determine the correct firewall and proxy settings.
5. Yahoo! Messenger will ask you if you want to sign in with your new proxy settings. Click the "OK" button.
2) In some cases you may have a local firewall or anti virus program that is blocking Yahoo Messenger or causing connectivity issues with it. You can try to disable any Firewalls you have and Anti Virus programs and see if you can now sign in. If so, then you will probably need to add exceptions in your firewall or anti virus program to allow Yahoo Messenger. If you need assistance with this step you will need to reach out directly to the company that makes the software. A google search by the application name or company name will bring you to the website where you can find help and contact information.
3) I have worked in Technical Support for many years and a simple but often overlooked step that works is to unistall or reinstall the program. There can be any number of causes for Yahoo Messenger program files to be corrupted or lost. A simple reinstall of Yahoo Messenger can get you back up and running. The best way to do this is through Control Panel in Windows.
-Go to Control Panel > Add and Remove Programs and find Yahoo Messenger in the program list.
-Click unistall and once removed go ahead and reboot your computer.
-Once rebooted, download Yahoo Messenger and install. Click here for the files.
-Once installed, reboot your computer again.
-Once rebooted try to launch Messenger and see if you can sign in.
4) At this point, if you have exhausted all the above steps, I recommend you contact Yahoo Messenger Tech Support directly. Click here for Tech Support.
I hope my article was informative. Check out some of my other Tips and Tricks by clicking on my Username at the top of this article and then going to "Tips" under my profile.
Regards,
G33k
Keywords
unable to sign in to yahoo messenger, can't connect to yahoo messenger, can't sign in to yahoo messenger, yahoo messenger not working, connect to yahoo messenger
on Jun 05, 2011 | Yahoo Messenger
Deactivate i'm mobile on my yahoo messenger
Good Day Denzfrance!
I'm sure you are seeing the I'm Mobile status on your name whenever you sign out of Yahoo Messenger.
That is because the "Always sign in to my mobile phone when I sign out of Messenger" was selected on the General tab of the Yahoo Messenger Preferrences.
To disable this process, follow this procedure:
1. Log in to your Yahoo Messenger
2. Click on the Messenger menu and then, scroll down to Preferences.
3. Select the General topic.
4. Make sure there is no mark on the box next to "Always sign in to my mobile phone when I sign out of Messenger"
5. Click Apply then click OK button.
After that restart your Yahoo Messenger. The next time you sign out, you will never be sign in automatically with your mobile.
You can comeback later and give this answer a good ratings.
Thank you for asking Fixya.
Jun 11, 2011 | Yahoo Messenger
Why my messenger closes when i open yahoo mail?
Hi
Welcome to FixYa.
Your yahoo messenger close when you open yahoo mail because on your yahoo mail the chat automatic sign in. For you to be able to sign-out that follow the steps below.
1. On the top page you will the see "Available" there is an icon "arrow down" click on that icon.
2. Click "sign out of Chat"
3. You will be offline for chat on your yahoo mail
4. Then sign in on your yahoo messenger.
Hope this information can help.
Thank you for using FixYa.
Mar 23, 2011 | Yahoo Messenger
How do I stop yahoo messenger
Hi , when you enter your username and password in yahoo messenger , you are logged in. To log out of the yahoo messenger, click on messenger, which is in left top side of yahoo messenger . when the drop down open's, click on sign out. Now you are logged out of the yahoo messenger.
Feb 13, 2011 | Yahoo Messenger
I kept having the same problems with YM. Every time i tried to sign in, it won't let me sign in. it's about yahoo! messenger troubleshooter and It said " We can't let you sign in". I am sure it was not...
6. Enter your Yahoo! ID and password and click the "Sign In" button. use registry cleaner reg in out to solve registry error for messenger
Sep 13, 2010 | Yahoo Messenger
I have just down load the new messanger and i cant open it or if it do run it shuts down
There have been many issues and bug with the latest Yahoo Messenger update. So i would suggest that you install the version before the latest.
Aug 17, 2010 | Yahoo Messenger
I can't signing into yahoo messenger
It may be the server is down, it's been happening a lot lately or your Yahoo! Messenger connection information may be incorrect. Yahoo! will fix it soon. To configure your connection, what you should do? Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences." Enable the "Firewall with no proxies" option. Select the correct Internet connection type and country from the pull-down menus. Click the "OK" button at the bottom of the window. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button. Enter your Yahoo! ID and password and click the "Sign In" button. The above configuration works in most situations. (However, if you connect in this way, you won't be able to use the Voice feature.) If this configuration doesn't work, follow these steps: Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences." Enable the "No network detection" option and then click the "OK" button at the bottom of the window. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button. Enter your Yahoo! ID and password and click the "Sign In" button. If neither of the above options work, you're probably behind a firewall or proxy server that requires you to enter its address. Follow these steps: Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences." Enable the "Use proxies" option. Enter your firewall or proxy server's address and port number. Contact your network administrator (if you're at work), or your Internet service provider (if you're at home) to determine the correct firewall and proxy settings. Click the "OK" button at the bottom of the window. Yahoo! Messenger will ask you if you want to sign in with your new proxy settings. Click the "OK" button. Enter your Yahoo! ID and password and click the "Sign In" button. If you try all of the steps above and Yahoo! Messenger still can't connect, contact your network administrator, Internet Service Provider (ISP), or the person who initially set up your computer to ensure that your firewall and/or proxy settings are correct. Hope it was helpful!
Jun 09, 2009 | Yahoo Messenger
HP Compaq Presario V2000 Notebook Logo
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
