The unit is about 3 years old. I have cleaned the filter and all openings to the machine. Not sure how to tell if refrigerant is low. It motor and fan runs but am not getting any water in the bucket! Need to know if this can be fixed or should I just buy a new unit? Our basement is very damp and can produce 50 or more pints of water a day.
If you have a dehumidifier that is not producing any water
then you are wondering what you need to do to get this thing to work
for you. In some cases you may be able to do something and in other
situations there may be nothing that you can do.
If you do not hear the compressor running and the unit says that the humidity in the room is higher then the setting, then you have a problem with your dehumidifier.
A few things that can cause this are:
The circuit board relay has gone bad...replacement of this board will often cost more then a new unit. This also is a very common problem with many dehumidification units.
The compressor has failed...if
you hear a buzz for a few seconds, every few minutes, then you have a
bad compressor or at least bad start components on the compressor.
Either way it again is a costly repair.
If the compressor is running and the coils are not getting cold then you have a refrigeration system leak. Recharging or fixing these units is very difficult and is another costly venture compared to the price of a new dehumidifier.
If the compressor is running but the fan is not, this also will cause low water production and continual freezing of the coil.
If the compressor and the fan are running but the coil is totally blocked then you will get no water production. Air needs to be continually moved over the cold coil to get the water out of the air.
If nothing is running, then you may also have a control board failure. Or the humidity sensor or humidistat has gone bad which tells the machine to run. If the sensor says that the humidity is low enough then it will never run.
Also if nothing is running check the float switch or the bucket switch.
Many of these switches are very touchy and if you do not have the
bucket in place just exactly right it will not trip the switch to allow
the unit to run. These switches often are more fragile then they should
be and break easily. The good thing is that when available they are easy
to replace and relatively inexpensive.
There are some parts
available for a few brands, but with the prices for most of the parts
that you can replace running anywhere from 40.00 - 80.00 dollars,
replacement parts with labor to install them, makes a repair more then
the few hundred dollar cost of many of these dehumidifiers.
As
you can see there are quite a few things that can cause your
dehumidifier not to work. Systematically go through the list and
eliminate things to get to the bottom of the issue causing your problem
and then decide if it is worth spending the money to try to fix the old
unit. Only you can make that decision.
SOURCE: Frigidaire 50 pint dehumidifier freezing up and
Dehumidifiers freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
SOURCE: recently purchased a 50 pint Frigidaire 50 pint
Check the settings. Make sure that the humidity setting is at 35%. In the cooler fall weather, the dehumidifier will not collect much water when the temperature is close to 65 degrees in the area where the dehumidifier is located. Also, if the relative humidity in the space is not significantly above 45% then you will not collect much water. Check these conditions. The image below shows how to access the internal components of this dehumidifier. Unplug the dehumidifier and check the front and back grill for debris. Clean these parts if necessary. Check the evaporator for a frost pattern. If the compressor runs but you see no frost pattern on the evaporator, then you could have a sealed system problem. This type of failure is normally covered by the 5 year sealed system warranty.
