Question about Honda EU6500iS Inverter Generator
Stops generating and just idles
Genny will run fine for any amount of time and then just stop generating and go to idle. No overload alarm, oil alarm, or anything. Oil level is perfect, as well as air filter. The unit is well maintained. It did this during summer use when it was 112, but we are operating at between -10 to low 30's now in winter so I don't see overheating being an issue. If you shut the unit off for 30 seconds and fire it back up, it will generate like it should for any random amount of time, then the cycle starts all over. I should point out that the random amount of time is never shorter than 30 or forty minutes, but sometimes might only happen 2 or 3 times in a 10 hour day. Any help with this would be appreciated.
Posted by Jeff Henderson on
  • Mark Gibson
    Mark Gibson Apr 08, 2017
    What loads are you powering? Constant, intermittent, 110, 220, both? Does the green output light stay on when this happens? Is the red overload light (not the oil light) on? Also note that if the generator is going to idle, then the EcoThrottle switch is on. This is not recommended for use with intermittent loads (like motors) because it causes large voltage fluctuations when those tools are turned on, which in turn causes current surges.
Pavlo Stetsenko
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
Check if there any alarm on monitor by pressing button several times. It has code like E-number. Replace spark plug, fuel filter. Clean carburator, spark arrester. Check wiring of thermosensor.
Posted on Apr 28, 2017
5 Related Answers
Vitally Alcher
  • 1645 Answers
SOURCE: honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
Posted on May 22, 2009
SOURCE: Honda EU30001 generator causes erratic pellet stove operation.
Ok Motors and the like generally DO NOT really go all that well from a generator, what load does the Stove use?, You must add up the cumlitive "Wattages" of ALL things connected, see your generator is about 3000 Watts, 3KW, How much "headroom" is there between the two? Whats supplied versus whats being used? Purely inductive loads, like Motors etc, are less responsive than electronic loads. I suspect that your generator is NOT providing enough current to the Stove, especially when "Other" things are connected. also. Look, if the, any, generator is 3000 Watts really you should only load it up to a couple of KW's, 2.5KW being about maximum. To do what you are doing would require, IMHO, at least, 5KW, to get the "Headroom" of current drawn over current able to be delivered by the generator. Also inductive loads loose heaps of power and actually cause a higher draw. So that your answer, you must use it well, inside it's rating, not right up to the limit.
Posted on Feb 26, 2010
Anonymous
SOURCE: I have a small Honda
Make sure the fuel valve is on, if that does not fix it you will need to drain the bowl on the bottom of the carb. What model is it
Posted on Oct 28, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: I have a Honda gx 390 that powers a generator, it
This engine has a high temperature cutoff that has probably gone bad...
Check it out here
http://www.tradebit.com/filedetail.php/3070770-gx390-honda-13-hp-engine-parts-manual
You also can download the manual from this site...
heatman101
Posted on Dec 30, 2010
scott sabella
  • 70 Answers
SOURCE: I have two Honda 2000i
the generators are not built to be used in this application
Posted on Jun 12, 2011
I have a eu 6500is generator inverter that will run perfectly for any amount of time, then with no warning just stop generating and idle. No overload alarm. No oil alarm. Nothing will just idle. If you...
this sounds like a capasitor/resistor that is getting hot under load once it is switched off and cools down it works until it gets hot again similar to that of a cars ignition coil which will get hot and cut the vehicle out but once it cools it will start again.
Dec 07, 2013 | Honda EU6500iS Inverter Generator
Yamaha EF4500Ise Gennerator won't produce power.
Doe's it have a thermal couple on it? If so it could be bad and when it heats up it is killing your power.
Sep 18, 2012 | Yamaha EF4500iSE Generator 4500 Watt...
I HAVE A POWERMATE 5000 THAT SHUTS DOWN UNDER LARGE LOAD . I THINK I NEED AN IDLE CONTROL MODULE.THERE IS A 2 WIRE MODULE IN THE START CKT. #21009XA IS THIS IT AND WHERE DO I GET ONE .
Idle control comes into play when there is no power draw forcing the engine to idle with an electro magent. If you feel that the electro magnet is interfering with governor, temp remove the wire to the solenoid. Usually the idle control will not effect how the engine /gen output power. An overloaded condition will cause the engine the go the full throttle as the internal governor of the engine will try to maintain 3600 rpm. Overloaded condition will greatly shorten the life of the generator/engine. Try to use only about 80 % of rated power. Large motors can draw three times running amps. A compressor using 12 to 18 amps to run can draw over 40 amps to start.
If your generator could handle the load in the past, check the engine for loss of power, or the generator for faulty voltage regulator or capacitors out of range. Easy to check. Connect digital volt meter to plug /load and look at volt reading while running with no load and loaded. Voltage should stay between 110 to 120 under load and with no load (unless goes into idle mode). Good luck
Sep 06, 2011 | Coleman Powermate Powermate 5000W...
Honda eu3000is. runs but not putting out the full watts. Is this a cheap or expensive fix?
I have the 5kw Honda and have no problem, but I have never tried to run 5,000 watts either. It is reaching max rpms? Air filter clean? Good fuel? Oil? Have you run it much, or does it sit? How do you measure the wattage? Add up a bunch of things like, skil saw, pump, fridge, etc? Let's see, skill saw at 13 amps x 120 volts =1560 watts. Fridge probably idles at 7amps, starter windings use 10 or so amps, tv, 500 watts, computer, I would not run anything electronic with a genny, unless I had a spike protector on it. Check it out, hope this helps.
Mar 05, 2011 | Honda 3000 Watt Portable Generator
"I was welding with a
Your generator is a welder?? Yikes, the 220 volts coming out of the genny is not the same as the 220 volts running a welder, it is, but it isn't, the 220 volts used to run the welder are transformed into DC, in the 50 -150 amp range, the 220 volts coming out of your genny is 220 volts, AC, at 30-40-50 amps. Now exactly how were you welding with 220 volts AC? Remove anything plugged into the genny, check the oil, check the gas, make sure it is fresh, check the breakers, check the fuses, get it running, now don't try to weld with it again. Unless you have a big welder to plug into it and I wouldn't even do that because of the generator spikes. I might be wrong, but I have never seen a genny with a welder on it for home use.
Feb 06, 2011 | Coleman Powermate Powermate 5000W...
1990 GMC 350 engine stops while idling at light. Replaced distributor cap,rotor, spark plugs and cables, new battery. and air filter. Engine is running without missing and no hessitation. Starts strong...
The Idle Air Control runs idle speed, it may be stuck or just bad. its located at the left rear corner of the throttle body, make sure its plugged in.
Dec 06, 2010 | 1990 GMC Sierra
My kipor KGE 1000Ti starts fine but after several minutes stops generating and the red overload light comes on, with the demand for power left connected and the generator still running electrical...
You may be UNDERLOADING the generator and it may be unstable with such a light load... see if it might behave running a heavier load... put a 100 watt light on it as a test,
Jul 25, 2010 | Electrical Supplies
4000 watt buffalo tools generator: Engine Starts, but after a few minutes it cuts out and stops running. No appliances plugged in, drained gas(it did sit for 6 months), oil is full, Plug is good.
Idle speed jet or passage and/or high speed jet/passage is clogged. Remove the carb and inspect and clean thoroughly, then re-install. Set idle and high spped screws approx 1 turn and tune to run smooth from there.
Feb 05, 2010 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
My 1999 Alero has been stopping, especially while idling at a stop light. As long as the car is in perpetual motion, it runs relatively fine. When it stops, the engine oil light and the batter light come...
You don't have right AIR: GAS ratio of 14.6:1 at idle. If you don't have idle adjustment, you need to have throttle valve clean.
If it doesn't work, then your Fuel Distributor is drifting out of calibration.
Don't worry about check engine light comes on when the engine dies. It is designed that way.
Aug 11, 2009 | 1999 Oldsmobile Alero
Honda 2000i generator runs but cuts out after a short while...
Hate to state the obvious, but is the gas cap vent set to on while you are running it? Also, next time it starts to run poorly, loosen the cas cap. If it runs fine, replace the cap.
Jun 03, 2009 | Electronics - Others
Honda EU6500iS Inverter Generator Logo
207 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Marvin
Marvin
Mike
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
