If the keys are hard to push you could have something under them, try vacuuming the keyboard. If they move freely, but you need to "mash" them you likely have a bad keyboard with the keys you mention as keyboards use a row and column method to detect key presses, and the keys you mention are often on the same column.
turn it in and hit the blower with your hand most likely it will start and then that means you need a new blower motor.. most likely what caused your resistor to go bad.
john ok there is a knob with letters on it trying turning it to c . in essence what u r doing is opening a vent to allow cold air from the freeze into the ref. try different letters till u get one that u like.. ok
It would be easier to tell you how if you let us know what operating system. Try this though. Right click My Computer, Choose Manage, Choose Disk Management, Right click on the Volume of the drive not working and choose change drive letter. Pick a higher letter like X.
It sounds like the IC that controls the sounds has gone. Once upon a time they used to start with the letters TDA and other sets of letters that would make them instantly recognizable but nowadays it could start with anything so unless you know what you are looking for call out a technician. Good luck.
The letter "H" on your keyboard got stuck and it's like pressed down all the time. You can pop out the key then clean it. If the issue is resolved, you should not hear the beeping sound anymore when you boot up the unit. Or better yet, if your under warranty, contact Toshiba, 1-800-457-7777 and they'll be blad to repair your keyboard.
My Blackberry 8310 curve key board is not working properly. When I press 5 nothing happens on the screen, when i press 4,7,and some of the letters dont work at all till i move them arround .
camara has been working fine till yesterday, poewer won't turn on, to take pictures, but it turns on when i moved the tab to brouse pictures, bur when I switched it back power won't work
