Question about Casio CTK5000 (61Key Portable Keyboard)
Casio ctk 611 keyboard error
When I press a key, multiple notes are played. How can I reset so that only the one correct note is played?
Posted by Paul Milledge on
Reuel Teoh
    Champion:
  • Casio Expert
  • 411 Answers
Turn off "Casio Chord" &/or autoaccompaniment
Posted on Dec 17, 2013
5 Related Answers
Michial Gueffroy
  • 1140 Answers
SOURCE: MIDI Keyboard note delay problem, not latency problem PLEASE HELP
You are suffering from midi latency. There is a good article about this at www.thewhippinpost.co.uk/latency.htm There is also some good advice there.
Posted on Jun 23, 2009
David Shaub
  • 2976 Answers
SOURCE: Notes not holding
The key contacts need cleaned.
Posted on Aug 10, 2009
Fred Yearian
  • 5603 Answers
SOURCE: My Casio Privia PX-110 is playing two notes at
IF every key sounds like it is doing that, you may have two voices selected with one of them being transposed.
You may have an "effect" turned on that generates a chorus, layered or multiple voice sounds.
Posted on Dec 10, 2009
Fred Yearian
  • 5603 Answers
SOURCE: I connected my Casio CTK
Oh, oh... that is often called the "Dreaded MIDI Drone".
There ccan be more than one causes, however two of those are this:
1. The receiving device either does or does not respond to the note off command or only responds to the note on command with zero velocity, which is also now interpreted as note off. Check the MIDI implementation chart to determine this.
2. Two MIDI commands have merged without using a MIDI merger which makes sure ONLY complete MIDI commands are sent. If the commands are mixed, dreaded MIDI drone is assured.
Posted on Sep 07, 2010
Anonymous
SOURCE: Casio CTK-651 keyboard wont switch on
i want to repair the casio organ ctk 651 or ctk 731
Posted on Oct 19, 2010
Problem with casio CTK-691 keyboard
"can I do it my self or should I go to a professional to get it repaired"?
Get it repaired by a professional. Casio gives long warranty (5 years in Australia). Mine took weeks for Casio Service to repair. Many boards had to be changed.
Jan 25, 2012 | Casio Ctk691 Keyboard
I have Casio Ctk-496 and I have MIDI-USB wire. It all works, but Transpose button doesn't transpose and casio chord doesn't work with my computer. And all is still working even if I pull out IN wire from...
Casio Chord is internal to the keyboard and doesn't come out on MIDI. Transpose is similar and while the button may send a MIDI transpose type signal out, the notes will not transpose in your computer...
Mar 30, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
I have a CTK-496. I bought the usb to connect from the keyboard to the computer. When I have it activated on Fl Studio, but I press the keys, nothing plays but the regular keyboard. Its like the keyboard...
You have to install the MIDI type software in the PC to trigger the sound card's voices. You may also need a driver for the keyboard. Search the Casio site for downloads pertaining to your keyboard.
Dec 27, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
I connected my Casio CTK 496 to Fruity Loops DAW. I am unable to send CHORDS and note duration information to the DAW. If i press a note, while the Keyboard is connected to my DAW, my DAW outputs the...
Sep 07, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
An internal fuse is UNLIKELY.
More likely is either a bad connection/connector at power input or a bad or intermittent power switch.
Jun 24, 2010 | Casio Music
Can I use it as controller for Fruity Loops? How? Thanks. The model that I have is Casio CTK 496.
You can use this keyboard via MIDI to send note on/off information to FriutyLoops. Use for control functions will be somewhat limited to voice change, velocity, and aftertouch.
Jun 19, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
Notes not holding
Aug 10, 2009 | Casio CTK810 61 Key Keyboard
My casio 496 cannot connect to fruity loops
Unfortunately your model of Casio only has midi in and not midi out. You will be able to use it as an external sound module but not to input notes into Fruity Loops. In other words midi out of your computer to midi in of the Casio with the proper settings will play your Fruity Loops sequences through the Casio.
Jun 18, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
May 05, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Casio ctk-496 claims to be midi keyboard controller
Try downloading MidiOx and troubleshooting with it. It will show you if you have any midi activity and which channel your Casio is transmitting on etc.
Apr 04, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Casio CTK5000 (61Key Portable Keyboard) Logo
133 people viewed this question
Top Casio Music Experts
Ekse
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Casio Music Expert? Answer questions, earn points and help others
