Oster 5965 Electric Kettle Logo
Question about Oster 5965 Electric Kettle
The lid is stuck
The lid of my kettle does not open. When I push back on the button and pull upward, it does not budge.
Posted by R Tischler on
euphotic
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 11 Answers
Have you tried pushing your lid down to make sure catch doesn't hang-up before pushing back on the button and pulling it upward?
If that doesn't work it maybe damaged (melted by steam, overuse or gunked up with heavy mineral deposits) but to be honest we don't ever open ours. We fill from the pour spout just fine with the lid always closed. You can pour in your descaler the same way.
Hope this helps a little...
Posted on Aug 31, 2014
MY Oxo electric kettle model; 8710300 lid cannot opened, now it is stuck. HOw do I repair it. TK in advance Only be used for few months
I have searched for a picture but was unable to find one featuring the soft open/close lid.
The only suggestion I have is to dismantle the kettle far enough to remove the lid and identify the problem.
My pressure cooker is locked shut. It is cool but will not rotate to open. It seems a little pin comes out and stops the rotation. any ideas?
Most have a pressure lock feature. The pin ususally pops up and locks the lid when there is pressure inside. sometime when cooking thick liquids the pin can be stuck in the up position. Just push it down slide the lock back and open the lid..Sometime running water over the top will budge it.
The trunk in my 2008 LR3 won't open. That is, the
Hi,has your fob not got a blade in that will open the tailgate manuley.
2answers
1.7 l cordless kettle model JKC930C lid release does not work
Had same issue on 2 B&D JKC930C kettles. Just push in button (hidden under front of lid) located in the centre above the spout with a butter knife and the lid will open.
The warming button is stuck in the "on" position.
Push down on it toggles it on and off. Push down on it and it will release back up. Hope this helped...
Cushion lid release button sticks and the lid does not close
Over time the heat can causes the plastic parts to swell until the button that releases the lid gets stuck. The button can be easily & carefully pried completely out of the hole with a knife **note the orientation of the button and spring for replacement. Clean the button & hole but expect the button to still stick when re-inserted back into the kettle. Take the button back out and if you take a knife and gently carve/scrape away some of the plastic round the inside of the rim of the 'hole' and around the edge of the plastic button, you can remove enough of the plastic so that the button now moves easily back and forth in the hole releasing the lid. Good luck.
1helpful
I pulled the paper jam out, now printer will not print
Switch the printer off, remove the back cover, now you will see rubber rollers, try turning them slowly either upwards or downwards, if they move freely then proceed to the next step. Look for any paper or any loose pieces that are stuck between the rollers and casing, if so then remove it from the printer.
Close the casing at the back,Switch on the printer, now open the front of the printer, the lid should be pushed slightly upwards, you will see a clear ribbon and a round rubber bar, also you will notice the printer cartridges moving to the side as you open the lid of that printer. If the cartridges did not move back to the one side, it means that the guidance rod is dirty and sticky, even if it did move to the side, and you heard the grinding noise, take a piece of paper towel, wipe the metal rod clean, now take some clear vaseline, gently apply it to the length of the shaft / rod, now close the lid and open the lid after powering the printer. If the problem persist, it could mean that the roller gear is worn, this is situated on the one side of the round rubber feeder / roller. Try moving the roller with your thumbs, up or down. Is it jammed? Y then replace or have it repaired. N Close the lid, insert the paper and press the paper feeder button, did it load correct? Y then it is fixed, if not get back to me asap
2answers
How do I remove lid for cleaning
With lid in open position just pull it straight up and off.
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Narseman
Marvin
Marvin
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
