If you have an iPod nano or Fifth Generation iPod (iPod with video):
- Scroll down to the last menu option but don't select it.
- Scroll up one menu item. This should be Settings.
- Press the Center (Select) button. This takes you to the Settings menu.
- Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
- Scroll up to the third menu item from the bottom one. This should be Language.
- Press the Center button to select Language.
Select your preferred language from the list.
If you have an older iPod with color display (including iPod photo)
- Scroll to the fourth menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
- Select your preferred language from the list.
If your iPod has a monochrome display (black and white):
- Scroll to the third menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
If the instructions above don't enable you to change the language on your iPod, try using the "Reset All Settings" option at the bottom of the Settings menu. If the Reset All Settings option does not work, you can
restore your iPod back to factory condition and reselect the display language.
