Does a Honeywell RTH6580WF thermostat work with this heat pump?
SOURCE: Honeywell Thermostat RTH 7500
Assumed all the wiring are correct,
to change from manual switching from heat to cool, press [system] button ( left ) to go into system setting.
then press and hold the [fan] middle button untill option display 120
use up down button to select option 300 ( Manual/Autochangeover) ,
select 0 for manual, 1 for automatic. ( read caution in page 22 of installation manual )
Good luck
SOURCE: Changed out a Honeywell Thermostat with an Aprilaire Thermostat
The smell is usually dust on the wires for electric resistance heat.The thermostat shouldnt have anything to do with it.
SOURCE: I HoneyWell Heat Pump Thermostat
Honeywell 8000 is a great digital thermostat that works very well with a heat pump
SOURCE: Heat pump -> installing digital thermostat.
sounds like the thermostat is not energizing the reversing solenoid , unless you have some experience with electrics i recommend that you call a trades person, to check this problem a multi meter is required and requires the user to know how to work with power , please do not attempt it yourself ...
SOURCE: The
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Currently it has a totaline P474-1050 with six wires. R=Red, G=Green, Y1=Yellow, W2=White, W1=Orange, and C=Black. When I hooked up the Honeywell all that worked was the fan.
