Question about Hitachi 61SDX01B 61" Rear Projection Television
Hitachi 42" flat screen remote wont change inputs anymore
I USED TO BE ABLE TO CHANGE INPUTS BY MOVING THE UP DOWN ARROW AROUND THD SEE LECT BUTTON. NOW I NUST KEEP HITTING THE INPUT BUTTON. WHEN I GET TO HMDI 1 and hit select it wont work. I must use the buttonson thebottom of the front of the tv. I h a ve 2 of the same tvs with same remotes. I tried the other remote and have the same problem
Posted by Goggie on
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: Hitachi 60V500A Tv changes inputs by itself
Take the batteries out of the remote first and make sure none of the buttons are sticking. Good Luck
Posted on Mar 21, 2007
ginko
Ginko
  • 19396 Answers
SOURCE: Hitachi 50sv810 Remote
Now I have got the problem clear, depending on the TV model there can be no way to have this HR20 functionality on your TV.
Universal remote may not have full functionality on HR20 .
The TV remote should have a function to select the input on TV, this is often called AV selector, or on some old model it is activated by pressing the 0 button, check this out and let me know.
Posted on Jan 02, 2009
Anonymous
  • 336 Answers
SOURCE: No picture cant use remote to turn tv on/off or change station.
Hi,If I am understanding the remote control is not turning tv right? here's the one you need http://www.newtvremotes.com/Mfrs/Hitachi/HitachiTV/CLU-3842WL.htm God bless you.
Posted on Oct 02, 2009
Anonymous
  • 927 Answers
SOURCE: I have a hitachi rptv model #43FWX20B and the
Howdy;
Since you don't have any white lines with the red screen/picture I would say that the red bulb (CRT) is conducting too much. There is an adjustment control for that. The 'sceen' control is behind the speaker cover and service cover. Turn red screen control slightly to the left until you get a good black and white picture.
Good Luck, Big Irish.
Posted on Nov 22, 2009
Testimonial: "Thanks Big Irish, Turned down red slightly and picture is perfect. I always loved the picture I got from this tv. Thanks and Happy Hollidays"
How to reset hitachi 51f59a
You can change input using inputs button on remote or the TV button to bring it back to the correct live TV source. Here is your manual: Hitachi 51F59 Operating Manual
Oct 13, 2018 | Hitachi Televison & Video
How do i change to av on my hitachi c2143s without a remote
As there is no Menu button on its front panel, you must have a remote control to select inputs.
Nov 07, 2012 | Hitachi C29-RF80 29" TV
Hitachi TV turns on but cannot get channels.The blue light and power lite comes on. Changed batteries in remote, still no channels
sounds like a simple input problem, find the input button on the remote or the tv and change the source input until you get a picture,
May 28, 2011 | Hitachi 42 in. Plasma TV
Hello, how do i change the setting to hdmi on my tv? thanks :)
When your HDMI cable already hooked up to TV via HDMI input, press button SOURCE on the remote control. You must see all the inputs there. If you don't see, keep rolling down the arrow button. You will see it. When it got highlighted, press Enter, your TV will switch to HDMI inputs automatically.
Aug 15, 2009 | Samsung LN32A330 32 in. LCD TV
No remote tv was given to me hooked up all I got was a black
black screen means that you need to change the input or it is not hooked up correctly with the cabling. if no "input, a/v, source or tv/video" button on tv itself will need to purchase universal remote. if you do have one of those buttons continue to push it several times pausing a few seconds in between and look for a picture. also you can try channeling up or down to ch 3 or 4 or sometimes even channeling down/up will change the different inputs (depends on the tv) hope this helps
Apr 04, 2009 | Gateway GTW-P42M303 42 in. Plasma...
Can not change inputs.
seems to be fixed. the only change was a shot surge ptotector. if its a short the problem will return.
Mar 23, 2009 | Hitachi 55HDS69 55 in. Plasma Television
No signal
you have to take the remote, find the input button, push the input button untill your picture comes back, you should see the input go from cable/antenna, to vid 1--vid2---vid3---if pushing the button a couple of times dont change it, you will have to hit the input button, then arrow down, and select the nexy one, do that untill you find the picture
Jan 10, 2009 | Sony KDF-E42A10 42 in. LCD Television
42HDS69-INPUTS
couple of ideas ... on the TV look for the button named input you can change it to the one you cave connected to there .. I am looking up the remote press the TV button then the menu button to move through the on screen input control
Sep 19, 2008 | Hitachi 42HDS69 42 in. Plasma Television
No Blue Hitachi 50v500
Yes, find a good signal on ch 3 either from a vcr or straight cable. If you change to another input you will adjust set for that input or for that format. Make sure once again that you don't change any settings except the one in question...memory init. You may have to push arrow twice to save changes but I'll check on that. If all else fails you may need light engine.
Jun 10, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 61SDX01B 61" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Paul Bade
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
