I am replacing the bearing and Shaft in my Cabrio Washing machine (Mod: WTW6600SW2). The shaft is not budging. I tried hammering it from the bottom and it did not budge from the basket. So the basket is out of the machine with shaft attached (I have removed all bearing, just shaft is stuck to basket). Any suggestions how to free shaft from basket?
SOURCE: I am replacing the bearings
ok..i will give you a couple of solutions go slow ,,becaues i understand your trying to save your spin tube,,did you try and soak it with wd 40....now what i do is set the plastic outter tub on a solid edge
and let the inner metal basket dangle..and whit a nice 2 pound hammer and i use a nut drive pund down evenly ..its hard no quetion in some case because the metal shaft swell up,,,most inner spin tubes are stainless steel so they have a lifetime warranty...if you can get a helper you can try unscrewing the parts the helper turns one way and you another...good luck
Hi
In a washing machine, the bearings protect the drive shaft from over rotation due to the forces applied to the washtub.
Unplug the washing machine from the power outlet. Turn off and disconnect the washer from the water pipes. Pull the machine forward so that you have easy access to the entire machine.
Unscrew the lid's top two screws and remove the machine's top panel.
Slide out the machine's back panel.
Slide off the fan belt and set it aside.
Unscrew the drive shaft's end bolt. This is the bolt that holds the pulley into position.
Remove the pulley by placing the screwdriver underneath it and gently leveraging it off.
Remove the drum's three bolts that hold its spider bracket into place. If the bolts are sticking use, rust remover and degreaser to loosen them. Do not apply too much pressure to the brackets or you will strip them.
Tap the spider joint gently with a hammer while pulling on it. The entire joint and the bearings should slide off.
Clean up the spider shaft, removing all rust and debris using cloth diapers and rust remover and degreaser solutions.
Tap the new bearings into place.
Tap the new drive shaft seal into place. The drive shaft seal should always be replaced with the bearings to ensure water-tight protection for the machinery.
Reassemble to washer.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
