SOURCE: GE Dual Wave II microwave oven blowing fuse
It sounds like a shorted high voltage capacitor, a fairly cheap fix. But if it's good, I would suspect the high voltage transformer.
Here are some links you or a friend can use for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
There
should be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
SOURCE: GE Dualwave II MIcrowave System - use of the convention oven time
You can download GE
owner's manuals and installation instructions here.
We're
SOURCE: GE Dual Wave II Microwave System and Conventional
I think I understand what you mean. If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers and Driver
downloads
as required. Just Google the manufacturer's name and
follow the links. Make certain you are directed to the manufacturer's
web site as some search engines direct you to other sites and they
charge for the information that is normally free of charge. The magnetron may have either failed or
is not being supplied with the extremely high voltage required to run
it. I hope this helps.
Make sure the !!!!capacitor is discharged!!!!!
before attempting any sort of repair.
Check the door interlock
switches first then the high voltage diode with either an AVO model 8
on high resistance range for short circuit, the feed fuse on the
primary of the high voltage transformer and then finally, the
magnetron is best checked by substitution.
SOURCE: i have a magic chef
It sounds like the magnetron may have
either failed or is not being supplied with the extremely high
voltage required to run it.
discharged!!!!! before attempting any sort of repair.
Check
the door interlock switches first then the high voltage diode with
either an AVO model 8 on high resistance range for short circuit, the
capacitor can fail and go short circuit, the feed fuse on the primary
of the high voltage transformer and then finally, the magnetron is
Hope that helps.
SOURCE: How do I use my
The model number is just fine, it's AMW 502 ix.
Here you can find and buy the user manual - it has all you need in it
http://www.user-manuals.com/advanced_search_result.php?keywords=whirlpool%20amw%20520%20ix%20manual&forward=plist
