Question about Canon PIXMA iP3500 Printer
Ip3500 printing misaligned vertical band
My printer started printing a vertical 'band' about two thirds of the way across any photograph I print, no matter what size. I have done all the maintenance checks, cleaning, deep cleaning, print head alignment, roller cleaning and tray cleaning to no avail. I uninstalled the printer software and re installed it. I have just bought and installed a new print head and replaced all the inks. The results are as follows: On a document A4 size paper with 2cm borders all round, I printed 'The quick brown fox.' twice on each line in size 12 font, Times New Roman so that I could see any problems, as the typed lines repeated exactly under each other. I did this in black only, then black 6 lines, red 6 lines, black 6 lines, blue 6 lines, black 6 lines, yellow 6 lines, black 6 lines, green 5 lines and finally black 5 lines. On the black only sheet, line 9 looks slightly italic because the top line of each character is one 'pixel' to the right, line 20 has the bottom line of each character has an 'extra pixel' on the left, line 23 the top of each character is one pixel to the left, line 26 the taller characters T, k, b, j, l are one pixel to the right, line 34 the bottom line of each character is one pixel to the right, line 37 the top part of each character is one pixel to the right, line 48 the bottom part of each character is one pixel to the left and line 51 the top part of each character is one pixel to the left. In addition, the first 'dog' has a thickened stalk on the 'd' all the way down the page. On the sheet with colours, line 9 (red) the top part of each tall character T, k, b, f, j, l are one pixel to the right and in addition the second e is overprinted with another e one pixel to the right. Line 10 (red) the top part of each character is one pixel to the left on the first sentence, but the second sentence is OK. Line 11 (red) the top line of each character is one pixel to the right in the first sentence, the second sentence is OK. Line 12 (red) the bottom part of each character is one pixel to the right. This continues down the page affecting lines 13 (black), 21, 22, 23, 24 (blue), (35 yellow), 40 (black) 45, 46,and 47 (green) in similar patterns - the characters are one pixel out, either to the left or right. The problem started when a piece of paper got jammed in the printer. I could not remove it and put the printer off, hoping it would eject the paper. There was a noise as if the carriage was stuck. I lifted the lid and could see that it was stuck against the crumpled paper. I put the lid back down and after about 5 seconds, the carriage returned to the 'rest' position. I tried again to remove the paper and managed to ease it free via the bottom paper tray (not where the paper feeds into the rear tray). Can my printer be rescued? I am not sure what to do, as changing the print head was my last option. Is it a hardware issue? Regards Gentleman Jim
Posted by Gentleman Jim on
hamid halim
    New Friend:
  • 3 Answers
My copier nashuatec 3722 .when start copier give me code E-4
Posted on Dec 07, 2013
4 Related Answers
Anonymous
SOURCE: Multiple Problems Printing
Replace the print head, and all should be just fine.
Posted on Jan 24, 2008
Anonymous
SOURCE: canon pixma ip500 horizontal bands of non-printing areas
Hi it's Gill again. I've been looking around more on the net and I think the problem is our printers need new printheads which I'm told are spare parts easy to change. Hope this helps. Gill
Posted on Apr 03, 2009
aicaxz
Anjazmoro Wicaksono
  • 511 Answers
SOURCE: Colour printing comes out in lines across the whole page
Is the nozzle is perfect? i dont think so. But, if you print with best/photo mode is ok.
Posted on Jun 01, 2009
Anonymous
SOURCE: Canon Pixma ip3000 printer, changed black ink
i had the same problem and just repeated the cleaning and testing, eventually the black showed up but took more than a few repetitions
Posted on Jun 30, 2009
Vertical bands
Clean flat bed glass. see the snap shots for areas to clean.
Dec 15, 2011 | HP Photosmart Premium C309A All-In-One...
Hp laserjet printer is printing a large vertical
if the band is white, you may have a problem in your laser scanner assembly, if the band is black, you may have a problem in your fuser assembly
Mar 30, 2010 | HP LaserJet 1012 Printer
Epson r300 - banding problems on print out
Nozzle check is fine? I am not sure. Check again. There is transverse and vertical lines. Is it perfect? Turn off printer, move head to center, put wet tissue with hot water at head cleaning mech. (pad). move head to parking position, wait for 15 minutes, repeat for 3 times. Check nozzle.
Jun 11, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Lines appearing across printed photographs
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 02, 2009 | Canon MultiPASS MP700 All-In-One InkJet...
Is there any debris under the printhead nozzle plate?
Jun 22, 2008 | Epson Stylus Pro 4800 InkJet Printer
Canon PIXMA iP3500 Printer Logo
136 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
