Question about Samsung HT-X200 Theater System
Cant hear my digital tv through my home cinema speakers
Hi i have a samsung LE40R88BDX/XEU tv with built in free view and a samsung htx-200 home theatre. The sound is fine with watching a dvd but when i try to watch digital tv through my home cinema speakers i get nothing. i have connected the tv and home cinema with a hdmi cable and also have a digital optical cable running between the two, where am i going wrong?
    Sergeant:
  • 339 Answers
Http://www.dummies.com/how-to/content/how-to-connect-an-hdtv-to-your-sound-system-or-home-theater.html
Matthew, I found this link which covers the basic possibilities for connections. It has a video backed up by the text version as well. Hope it helps.
Posted on Dec 07, 2013
2 Suggested Answers
Anonymous
SOURCE: Gurus, I just bought Samsung Home Theater System which i connected to my Hitachi TV with HDMI cable. I have a Optical Cable going from HT to my TV Optical port. I have another connection from my cable
On the remote control for the Samsung Home Theater System look at the bottom left to a button that says "MODE", those moods change the sound each speaker gives off. if that doesn't work, you might need new wiring because there are other wires that are more durable than the ones that come with it, much better too.
Posted on Jun 03, 2009
fahadn
  • 21 Answers
SOURCE: Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Posted on Sep 14, 2009
How to connect a Panasonic SA PT950 home theater syst. to a Samsung flat TV UN65JU650D?
Samsung 40'' 720p tv and Panasonic home theatre system ...
? 5:30
https://www.youtube.com/watch?v=zDG-PZtqCNE
Jan 4, 2012 - Uploaded by Nazil Rahman
Samsung 40'' 720p tv and Panasonic home theatre system ...How to Connect an HDTV to Your Sound ...
New way to connect TV to Surround sound using HDMI ARC ...
? 4:46
https://www.youtube.com/watch?v=fFNEKnlQd6I
Dec 13, 2013 - Uploaded by Tampatec
How to Connect TV to Surround sound receiver system setupusing HDMI ... to Samsung, LG, Sony, Vizio ...
Unable to connect Samsung smart TV with Panasonic home ...
www.tomsguide.com/.../unable-connect-samsung-smart-panasonic-home...
Dec 16, 2014 - hi I bought Panasonic SC-BTT405 blue ray disk 5.1 home theater and ... Unable to connect Samsung smart TV with Panasonic home theater ... I have an LG55LA9650 smart TV hooked up to a Bose 3-2-1 home theater system.
Jan 23, 2016 | Samsung Audio Players & Recorders
Is this samsung tv LE40R88BDX/XEU digital?
Refer its user manual to get more details. Its specification page will give you all you want to know.
Jul 05, 2015 | Samsung Televison & Video
Hi I have just purchased a Panasonic Plasma TV and Panasonic home theatre. Everything works well except for I cannot get sound coming out of the home theatre when watching normal TV. I purchased the...
Try running the audio from each video source (NOT the TV, which is an output, not a source) to the HTR digitally so you'll get the best mutichannel sound possible. Then you can turn the TV speakers (assuming it has them) off for hi-end watching.
Aug 15, 2010 | Panasonic Audio Players & Recorders
Hi, My SAMSUNG LE40R88BDX/XEU LCD 40'', isnt working! When you turn the TV on it sounds like someone is constantly turning it on and off with the remote, as its making a constant switching on and off...
It sounds like the power supply board has some bad capacitors that need to be replaced. Samsung is covering the cost to repair this problem on some models. You can call 1-800-samsung to find out if your unit is covered.
Apr 02, 2010 | Samsung LE40R74BDX 40 in. LCD Television
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
I have no surround sound when watching normal T.V
Hi there, in order to listen to t.v you need to purchase an optical cable and plug this in the optical out of the tv to the optical in on the blue ray then select D.IN.1 on the blue ray and press mode on the remote until it says matrix . This will allow you to listen to the t.v through all speakers. hope this helps. Also remember to take the rubber protectors off the ends of the optical cable, a lot of people forget this :)
Nov 17, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
I have no sound from my samsung tv to Samsung HT-TZ315R/XEU i have connected with hdmi and the white and red plugs i have sound from the dvd player but not the tv any suggestions
Make sure the red & white connectors you are using on the TV are actually audio out, and not audio in. If you are using the connectors on the side of the tv (adjacent to the yellow connector), then these are inputs.
If your TV has no audio out connectors, then if you have a European TV, you can use one of the scart connectors with an adaptor.
Also, check the red & white connectors you are using on the home theatre system are inputs. Also check the source is set correctly.
May 16, 2008 | Samsung Televison & Video
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
Samsung HT-X200 Theater System Logo
213 people viewed this question
Top Samsung Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
