Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook Logo
Question about Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook
Cd drawer will only come out half way,gateway acer laptop and i have to pull it our half way
Posted by patti capps on
Need a recovery cd for gateway laptop NE56R41u
did you ask Gateway? we are not Gateway.ask them?
no symptoms stated, just a CD. (it be dvd not cd, cd to small)
6 years old, can I guess windows 7 you want?
Acer owns Gateway now.
here i am asking there now for you typing
this is how you get the facts.
https://community.acer.com/en/search?adv=&search=install+disks+for++windows+7&title=&author=&cat=all&tags=&discussion_d=1&discussion_question=1&discussion_poll=1&comment_c=1&comment_answer=1&within=1+day&date=
How do I open the CD drawer on Toshiba satellite lap top
Turn the laptop off first.
Get a file clip, straighten up nicely atleast half of the length, Now carefully look for the whole which this clip just fits in on the face of the CD drawer. Insert it gently until it hits something and once it hits, gently give a little push, it should open the drawer.
Need a recovery disc for my acer gateway that i can download
Download the recovery CD and device drivers from the Acer WEB site. Make sure you select the model of your laptop the drivers you that require that matches the Windows version that is installed on your laptop. Use this link to get to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Is the gateway nv53780 series have a cd burner
Look at your cd drawer. If it says DvDrw or CDrw then it will burn CD's. Sometimes it might say CD Rewritable.
If it doesn't you can always purchase one that can go inside the laptop or you can purchase one that can be external and connects through the usb ports.
DVD CD Rom is faulty. Need to know how can I remove it from the laptop acer emachine 5118
Turn the laptop onto its top look at the base area casing where the DVD is inserted and you will see two small screws.
Take these out and then turn the laptop back onto its back , use a paper clip and insert it in the small hole in the front of the DVD drawer , the DVD drawer will slide open
Use this as a lever and gently rock the DVD unit side to side while pulling and the whole unit will slip out
How to replace Acer travelmate 4011 CDROM
Look underneath at the base plate
Under the CD-Rom unit there are two screws with arrows against them
Remove these screws
Get a paper clip and press it into the small hole on the front of the CD-Rom and the loading drawer will spring open
Use this as a lever to gently pull the unit forward and out
You may need to rock it slightly from side to side
To fit new one . just slide it into hole and press
4helpful
Cannot open cd drawer
If it will not open by itself, open up a small paperclip and push it into the little hole on the front of the cd rom. This will release the latch, and allow the drawer to open
My DVD Drawer will not open on my Gateway Laptop
My dvd drawer will not open on my
Gateway Laptop
2answers
Acer Aspire 3610 wont brun cd's
maybe you have a defective dvd writer try to use usb external dvd writer
Mehandi Husain ...
Steve Sweetleaf
Steve Sweetleaf
