Can't get pass step 2 to restore my c drive. What do I do?
Enter Safe Mode and select "Restore File System". "Restore File System" will attempt to repair damaged files on the hard drive. If this does not work, try the next step.
2. Rebuild Database
Enter Safe Mode and select "Rebuild Data Base". "Rebuild Data Base" will erase messages, playlists, changes made on [Information] screens, trimming information for pictures in [Photo], video thumbnails, video playback history and video resume information. Then attempt to rebuild the PlayStation 3 database. The content that is erased will not be recoverable. If this doesn't work, try the next step.
3. Restore PS3 System
Please note this will erase all content on the hard drive and will not be recoverable.
Enter Safe Mode and select "Restore PS3 System". "Restore PS3 System" will restore the default settings and will format the hard drive. If this doesn't work, try the next step.
4. Re-seat the hard drive
If you have replaced the hard drive in the PlayStation 3, make sure it was installed properly. If the hard drive is not seated correctly, it may cause problems.
5. Try another hard drive (if possible)
There may be an issue with the hard drive that is installed. Try replacing the hard drive with another one.
