Question about Yamaha Electrical Supplies
I have a Yamaha 650DE gasoline powered generator which when started comes up to speed, then quickly stalls or nearly so only to speed back up then once again almost stall; repeating this sequence until it's shut down
Posted by thom spears on
tebrown507
    Sergeant:
  • 415 Answers
This sounds like a fuel supply problem. Probably gum or varnish in the carbureator. Rebuild the carb and it should be fine.
Posted on May 23, 2014
5 Related Answers
Anonymous
  • 72 Answers
SOURCE: conversion of Yamaha gasoline electricazl generator engine to natural gas
My answer:
Hello Bill:
Here are the site links you'll need to check and/or get info, or buy your adapter kit for your Yami YG4600D Genset conversion kit.
Most likely it's running an 8 or 10HP engine on it now? In any case it's most likely less then 12HP. Not sure what size engine you have, as you didn't say only for the model #? On older Gensets it's harder to track down the HP rated engine is all.
For your Yami YG4600D Genset there you most likely will have your choice of at least 4 adapter kits depending on if you are going to keep gasoline as an option. If you're definitely NOT going to be ever running gasoline again then there are 1 or 2 adapter kits to choose from.
Use the site links below, and then browse whichever area you want as there are many options there. The last link listed takes you through all the different engines by make & model #'s.
I would also shop around locally where you are in LA, as you might be able to get that adapter kit for a lot less then the $227 to $267 they are asking for there at that site.
If you don't see your exact model # (or kit) there call them on their 800 toll free # listed at their site.
Also - if this site doesn't meet your expectations customer service wise at least you will have a starting off point with the wealth of information supplied there!
http://www.propane-generators.com/what_kit_do_i_need.htm
"What Kit Do I Need?"
http://www.propane-generators.com/simple_explanation.htm
"Simple Explanation"
http://www.propane-generators.com/a-c_kit_list.htm
A and C Kit List
Please post me a reply as to this info helping you solve your adapter kit problem there by following my posting recommendations above. Also please rate my troubleshooting fix as well.
Keep me posted and I'll follow up as well.
Best regards,
Frank
Posted on Sep 07, 2008
Anonymous
  • 583 Answers
SOURCE: conversion of yamaha gasoline generaor into natural gas...
i know YAMAHAwere doingsome work on converting outboard motors to run on LPG they may be able to get a bit of info from the STATE distributors might be worth a phone call
Posted on Aug 10, 2009
Anonymous
SOURCE: How can i fix my nixon gasoline generator
Hello, yes this sounds like a small blockage in the carburetor,
My first stem would be undo the carb bowl and clean this out, also make sure the float works ok and shuts the fuel off when in the up posission..
strip and clean the carb but pay attention to the screw what holds the carb on, not sure if this type has small holes in what lets fuel into the engine? also where the screw holds the bowl on, inside there holds another jet, this gets blocked, make sure its clean and you can see through it..
Make sure you usse the correcy size screwdrivers as these brass screws split very easy and can be a pain in the *** to find replacements..
if you need any more assistance send me a msg.. [email protected]
Dean
Posted on Feb 06, 2010
Anonymous
SOURCE: My Coleman Powermate generator runs for ~60
take out the jets , and run small wire through all holes .should fix your problem
Posted on May 02, 2010
Anonymous
  • 31 Answers
SOURCE: Yamaha Portable Generator EF 1000
Try cleaning the carb out,(hog wash carb cleaner I use) the float may be stuck or the needle & seat.You may need a rebuild kit for the carb,about 12 bucks.hope this helps
Posted on Jan 10, 2011
Testimonial: "Good advice, thanks."
Fuji Micro Generator FJ6200Ri. What is starter Battery Voltage?
At present, the gasoline engine does not have 24 V, diesel engine has 12 V. The ignition of gasoline engines is different from that of diesel engines. Gasoline engines use spark plugs to ignite combustible mixture air to explode for work, so they do not need high speed. A low-power starter does not have to use 24Vstarter battery, while a diesel engine needs a high speed to do its work through a high-pressure spontaneous combustion explosion, such as the excessive volume of a 12V high-power motor. Therefore, the low temperature starting performance of 24V.12V diesel engine is generally used in low power diesel engine, and the application of deceleration starter solves this shortcoming.
Dec 26, 2017 | Fuji Electrical Supplies
Ridgid rd 6800 putting out only Low Voltage
Verify the engine is running up to speed. Measure rpms or frequency of the output voltage. Freq should be 60hz +-1hz
Sep 22, 2013 | Yamaha Ridgid Rd6800 6,800-watt Gasoline...
Yamaha EF1000is inverter generator, never tused, won't start
Try searching for a fuel shutoff somewhere near the bottom fuel line exit for the fuel tank on somewhere on the fuel line.
Nov 12, 2017 | Yamaha 1,000 Watt Portable Generator...
3000 watt yamaha generator is really hard to start and when started it stalls under load.
sounds like the carberator needs cleaning and the linkage that makes it open up under load. it works off the flywheel. a lot of generator problems are gas related. water, trash and varnish build up in the carb.
Aug 25, 2010 | Yamaha 4500 Watt Electric Start Generator...
Hi output from generator
I found out that the gasoline motor was turning too fast so I had to turn down the speed of the motor with the adjustment screw.
Sep 06, 2009 | Northstar Generator 9 Hp, 5500 Watt,...
Might Buy is there a problem with their reliability
I would look at the honda and yamaha generators. Their small gensets are unbeatable and rugged as they come. Dependable as sunshine.
But, that's just my opinion!
Best regards, --W/D--
Aug 11, 2009 | Sunpentown SPT TG-1000CA 1000 Watts 2.0 HP...
Conversion of yamaha gasoline generaor into natural gas...
Jul 20, 2009 | Electrical Supplies
Electrical Supplies Logo
108 people viewed this question
Top Yamaha Electrical Supplies Experts
Sheldon Dedek
Robert Wooley
Robert Wooley
Dan Horsefield
Dan Horsefield
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
